Post by borris120 on Sept 16, 2013 15:45:35 GMT -6
Hello from SLC
Post by smallfryfury on Sept 19, 2013 15:06:26 GMT -6
Now I'm fairly certain the gear oil is leaking badly. Oil is coming up through the left of the floor board. The assembly (with the kick starter coming out of it) needs a new gasket. Whats involved in replacing the gasket? Should a newbie attempt it?
Post by smallfryfury on Oct 12, 2013 16:53:09 GMT -6
Fairly certain the oil leak is from a couple missing breather tubes. Here's another problem. The rear wheel is bent, if only ever so slightly. From what I've read online, this is a "write your will before you ride the scooter again" problem. Which makes sense. Any advice on repair/replacement? The wheel also gradually loosens itself, but I just gently make it snug with a 1" ratchet. Any help would be much appreciated.
