Post by eaglevip on Sept 18, 2013 10:34:49 GMT -6
I'm new to the whole scooter thing but I have a unknown brand VIP 50cc and love the look of the fatty rims. My question is do you have to do a stretch to fit a fatter tire or no
Post by rob63 on Sept 18, 2013 11:07:30 GMT -6
You don`t have to do a stretch but your handling will be a bit odd to say the least. There`s also more to it than just popping a wider rim on. You need to off set the engine to one side of the centre line of the scoot, then get an offset rim, then get a hub to accept the rim. Quite a lot of work is involved. Best place to get an idea of what is involved is to have a look at the Total Ruckus forum.
Post by eaglevip on Sept 18, 2013 19:29:46 GMT -6
Thanks for the reply I checked out total ruckus before that's where I got the idea but a second question is what if any parts for a ruckus will work on mine. I'm planning on pulling the body panels off anyway since most are trashed and i like some of the handlebars for the ruckus
Post by rob63 on Sept 19, 2013 11:14:49 GMT -6
The only way of telling is to take measurements unfortunately. Most of the Ruckus on the forums have a GY6 150 engine as a base. Yours being a 50 has different mounts to the 150. Have a search on there for 139qmb, it should throw up a few 50cc bikes
Post by jct842 on Sept 19, 2013 12:38:50 GMT -6
Also factor in that it takes a lot more power to push a fattie tire around, the rolling resistance doesn't mean as much if you are using a larger motor.
