Post by Deleted on Feb 7, 2014 13:19:31 GMT -6
Post by cyborg on Feb 7, 2014 17:30:44 GMT -6
go for it laddie!!!!!!!!
Post by kz1000st on Feb 7, 2014 18:39:24 GMT -6
The 50cc China scoot motor is possibly one of the best in the world. I don't think too many other scooters would run and function in that state. I gotta get me one someday.
Post by twowheeler on Feb 7, 2014 18:55:04 GMT -6
Throw it back! LOL
Post by LUKE on Feb 8, 2014 3:15:00 GMT -6
that scooter was in the backyard for only a week and it accumulated that much rust already?? ahh indeed ,, a chino scooter,,, well good luck buddy
Post by markwb on Feb 8, 2014 4:58:17 GMT -6
That thing does look rough, but I know you can bring it back to life. Best of luck with it and have some fun too!
Post by kz1000st on Feb 8, 2014 9:33:27 GMT -6
That thing does look rough, but I know you can bring it back to life. Best of luck with it and have some fun too! Yes. A Japanese quality scooter that lay in the mud for months and still runs? Amazing.
Post by Deleted on Feb 8, 2014 10:39:48 GMT -6
that scooter was in the backyard for only a week and it accumulated that much rust already?? ahh indeed ,, a chino scooter,,, well good luck buddy No Luke, it sat somewhere on its side in the mud for at least a year going by a Walmart ad in the underseat box that is dated July 2012. The beltxase was completely full of dirt to the point that you could not kick it over. There were actually roots growing inside. It had nearly no oil in it when I got it. The oil was gritty and had metal shavings in it.
Post by LUKE on Feb 8, 2014 10:54:51 GMT -6
you definitely need to replace the bell an the primary sheaves.. its a good project this winter... seafoam it right away.. check the diaphram inside the carb if its still intact.
Post by Deleted on Feb 8, 2014 11:15:31 GMT -6
you definitely need to replace the bell an the primary sheaves.. its a good project this winter... seafoam it right away.. check the diaphram inside the carb if its still intact. I've cleaned the carb. Its an unsealed one. Adjustable and actually not in bad shape. Back after I did that before snow I actually took it down the driveway and back. My driveway is about 400 feet long. Got up to about 25 mph in that span.
Post by cyborg on Feb 10, 2014 9:13:08 GMT -6
Hey lantern,,,your going to rucktify this thing correct?,,,i tend to go a little overboard on my bike work,,,i'd tear that thing apart to every nut and bolt ,,,clean sand paint wire brush everything then reassemble,,new belt hoses ,,,,but that's me and i don't wory about it being" worth the effort",,,,you got it for next to nothing,,i look at it as a hobby
Post by Deleted on Feb 10, 2014 10:08:32 GMT -6
It needs a good washing. Except for the corrosion on the engine mos of whats there is dirt. I'll provably get it fixed up eventually. Really busy here right now lol.
The other day I did get around to adjusting the valves though.
Post by randy on Feb 10, 2014 15:11:54 GMT -6
I have had many scoots and motorclycles with aluminium that looked like that. What I did and it worked very well was to clean it first with Eagle One Rough Cast alloy cleaner and when I was happy with the cleanliness of it I would spray a LIGHT coat of Dupli Color cast coat aluminum engine enamel. Held up very well looked new and was easy to clean.
Post by Deleted on Feb 10, 2014 16:05:12 GMT -6
I have had many scoots and motorclycles with aluminium that looked like that. What I did and it worked very well was to clean it first with Eagle One Rough Cast alloy cleaner and when I was happy with the cleanliness of it I would spray a LIGHT coat of Dupli Color cast coat aluminum engine enamel. Held up very well looked new and was easy to clean. Thanks for the tip! Might have to use that on my road worthy scooter as well
Post by cyborg on Feb 10, 2014 16:37:14 GMT -6
i aslo use duplicolor cast coat,,excellent product,,,in some cases indistinguishable from original
