Senior Clinician
Beedspeed
by: randy - Dec 3, 2018 7:10:38 GMT -6
Post by randy on Dec 3, 2018 7:10:38 GMT -6
I have had VERY GOOD luck with Scooter Mercato,good prices,fast shipping and and Dave is a standup type of guy.
Senior Clinician
Post by randy on Nov 15, 2018 17:26:31 GMT -6
Thanks ! I am fairly confident that is his problem and very confident that the fella when he sits on it it dies has the same problem. I have worked on several Stellas and this is for sure a problem with these bikes. Easy fix. I just get a chunk of new wire coil it around a round shaft screwdriver solder it to the existing wire extending it a inch or two and problem solved with zero comebacks.
Senior Clinician
Post by randy on Nov 13, 2018 16:49:41 GMT -6
Same as my other post. Check the 12 volt wire at the coil make sure the wire in the crimp connector is not frayed or loose.
Senior Clinician
Post by randy on Nov 13, 2018 16:44:51 GMT -6
Check the 12 volt power wire at the coil,had a similar issue and the wire inside the crimp connector was frayed.
Senior Clinician
NEW Toy
by: randy - Mar 30, 2017 6:05:26 GMT -6
Post by randy on Mar 30, 2017 6:05:26 GMT -6
It was a fun project with a few heartaches. It didn't need many parts,just a lot of attention to details. I would have liked to put a lot more aftermarket goodies on it but scootrus is not taking orders and the rest of the vendors were cost prohibitive.All in I have about $500 so I am ok on this one. The biggest expense was the cost of the paint it self.$63 a quart,plus catalyst,and reducer.
Senior Clinician
NEW Toy
by: randy - Mar 27, 2017 15:42:23 GMT -6
Post by randy on Mar 27, 2017 15:42:23 GMT -6
97% done!! runs and rides like new. Just a few loose ends to tie up! ![](https://s9.postimg.org/m35f0d297/001.jpg)
Senior Clinician
NEW Toy
by: randy - Mar 23, 2017 5:27:12 GMT -6
Post by randy on Mar 23, 2017 5:27:12 GMT -6
Here is a link to the ad. Asyou can see it needed a lot of love. But he took $200 for it and I got running without a issue.https://offerup.com/item/detail/184792395/
Senior Clinician
NEW Toy
by: randy - Mar 22, 2017 5:00:40 GMT -6
Post by randy on Mar 22, 2017 5:00:40 GMT -6
I cracked the code for posting pics. It is a 2003 Stella that needed lots of love{which it received} It is now painted and about 95% completed waiting on a few parts. Will post a pic. when it is done.
Senior Clinician
NEW Toy
by: randy - Mar 22, 2017 4:57:48 GMT -6
Post by randy on Mar 22, 2017 4:57:48 GMT -6
Senior Clinician
NEW Toy
by: randy - Mar 20, 2017 17:21:45 GMT -6
Post by randy on Mar 20, 2017 17:21:45 GMT -6
Sorry pics didn't work.
Senior Clinician
NEW Toy
by: randy - Mar 20, 2017 17:17:17 GMT -6
Post by randy on Mar 20, 2017 17:17:17 GMT -6
I found it on offer up for $200. Took about 15 minutes to get it purring and about a week to paint it.
Senior Clinician
Post by randy on Jun 19, 2015 14:57:44 GMT -6
I adjustuter the valves but the problem persists If you adjusted the valves it is not a two stroke.
Senior Clinician
Post by randy on May 7, 2015 5:36:57 GMT -6
It will cost only a few cents more to use premium so why not? I only use 93 octane with no ethanol. Over kill maybe but I know I have good fuel under my butt.
Senior Clinician
Post by randy on May 4, 2015 5:47:33 GMT -6
Older 2 strokes tend to be horrible on fuel,,,modern ones are way better,,,still not as good as a four stroke tho I think we could debate that. I have had a bunch of the GY6's and I think the Stella is right there in mpg possibly better. I never checked the mpg's that close but around town the Stella is getting better than 85 mpg. But if I do take it and run at higher speeds 50 or so for long periods of time the mpg does drop quite a bit.
Senior Clinician
Post by randy on Apr 27, 2015 16:00:38 GMT -6
I had a 500 and 750 Kaw three cylinder two strokes back in the day and they ruled light to light. Also had a Suzuki GT550 3 cylinder Very nice bike good power,quiet and smooth. Alot of people were shocked it was two stroke.
