Post by redwood0318 on Apr 4, 2014 10:24:17 GMT -6
Recently my scoot has had problems staying charge at random times. ive tested the battery and it holds almost 13 volts easy for two days. I saw something on you tube about your voltage while the engine is running should be 12-15 but never more than fifteen. If thats true then what problems could that cause? and What is the best way to fix it. i havent blown any bulbs. no fuses are blown. Is it the regulator rectifier? The engine is a 1p39qmb. Thanks for the help!
Post by Alleyoop on Apr 4, 2014 11:18:00 GMT -6
Batteries loose their charge just sitting there. What is the voltage after two days of sitting?
A battery will also loose charge if the scoot has an alarm, or digital clock built in the the instrument panel. Alleyoop
Post by redwood0318 on Apr 4, 2014 23:33:22 GMT -6
is over fifteen volts normal?
Post by Alleyoop on Apr 4, 2014 23:52:18 GMT -6
is over fifteen volts normal? No if it is charging over 15+ volts it is overcharging and damaging your battery. That points to a bad Regulator/Rectifier it is not regulating the DC voltage. A optimum charging system is 14.5-14.7 but really anything over 13+ volts is okay. Alleyoop
Post by tvnacman on Apr 5, 2014 14:51:15 GMT -6
I had a scooter in the shop with a charging problem , it was not charging . I figured out it was the regulator I replaced the regulator . Then had the same problem then it started to charge . I found the headlight switch was shorting internally loading down the charging voltage . Very strange problem .
Post by Alleyoop on Apr 5, 2014 15:09:14 GMT -6
The trick is to check what the output of the R/R is NOT to check at the battery terminals. That would have told you the R/R was good that it was something else drawing to much juice from the battery. Alleyoop
Post by masterburt on Apr 8, 2014 2:16:51 GMT -6
I had this problem but with a 139qmb engine.i just changed the wirng loom including components and sorted it,cheap nasty chinese bikes Never again
