Post by jun on Aug 5, 2014 21:46:58 GMT -6
I have replaced all the light bulbs to LED and changed the headlights to 35W H3 bulbs and JR was right! Now i am getting 13.1 - 13.4 tops! THANK YOU VERY MUCH YOU GUYS FOR ALL THE HELP! HAPPY CAMPER HERE! THANKS SCOOTERDOC!
Post by jun on Jul 29, 2014 21:46:01 GMT -6
According to the manual for this scoot the electrical system output is 98watts..the break light is 5w and when you hit the break it goes bright and it burns 21w i believe
Post by jun on Jul 29, 2014 21:42:07 GMT -6
I replaced the lamp on the steering with an led and and led bulb in the low beam projector and the battery is charging a lot better i am at 12.82-12.87vdc and that is the max it will go charging..i will try to replace the brake light with the 1157 tomorrow and will see how it goes..im just wondering why from the factory they put all these bulbs in the setup and the charging system cant keep up..
Post by jun on Jul 29, 2014 8:52:37 GMT -6
Here is another link with all lights plugged in.
Post by jun on Jul 29, 2014 8:35:02 GMT -6
Here is a link. All lights disconnected except dash board.
Post by jun on Jul 29, 2014 8:24:37 GMT -6
Okay guys. I unplugged all the lights except dash panel and the reading on my battery went 12.6vdc to 13.2vdc eveytime i rev it to 4-5k rpms Headlight bulbs are 55w rating and there is 2 bulbs, one for high beam and lowbeam. Breaklight is 21W and my turn signal bulbs are 21w as well. Once i plugged all the lights in the volatge drops to 12.2 and dropping slowly..
Post by jun on Jul 29, 2014 0:41:39 GMT -6
Traced the wires from the headlights back and no relay..is the cdi a relay?
Post by jun on Jul 28, 2014 23:34:55 GMT -6
Thank you all for the great input! I dont see any relay anywhere around the scooter and i dont know what a diode looks like am not sure..will wait for John and see what he says. Thanks again
Post by jun on Jul 28, 2014 22:55:35 GMT -6
i will definitely consider your opinion JR. here is what i did, i hooked the old r/r just for the heck of it and i got the exact same readings from the new one, it looks like the old r/r is not even bad after all..i wonder if i will purchased an 8 pole stator to replace my old one, how many types of 8 pole stator out there that i can possibly buy not the right one...
Post by jun on Jul 28, 2014 22:17:48 GMT -6
Brake light have 1 bulb and yes it is working alright. When i turn key on the brake light turns on, when i hit the brake levers the breaklight goes bright. All bulb sockets looks good and no corrosion at all..turn signals and all. Headlights bulb and sockets looks good too no corossion. Now i unplugged the light green wire from the regulator that goes to the auto choke and it did speed up the charging of the battery a bit, with the headlights unplugged. Now im getting 12.82vdc from the battery and slowly climbing up. But when i disconect the red wire with the fuse from the battery and test it, red probe to the red wire and black probe to the negative wire that goes to the ground i am getting 3.5vdc with the motor running
Post by jun on Jul 28, 2014 21:45:51 GMT -6
JR,
I already inspected all the connections and grounds they look good no visible corossion. Tested all wires with continuity and all came out good. Not unless i missed something which is i made sure every single wire i checked..one wire actually broke, it is the black wire that goes to the negative terminal of the battery and put a new wire for it
Post by jun on Jul 28, 2014 21:39:26 GMT -6
Main plug from the stator there is 3 wires green white and yellow, then two wires that are bullet type connector one is white/blue and the other one is red/ black so total of 5 wires coming out of the stator.
Post by jun on Jul 28, 2014 21:26:08 GMT -6
Alley,
Yes, when scooter is running without the battery all lights are on but super dim, once i connected the battery all lights goes super bright.
Post by jun on Jul 28, 2014 21:18:12 GMT -6
Headlights disconnected it seems it is charging the battery very slowly 1v every 5secs evrytime i rev it to about 4000rpm. As soon as i connected the headlights oh boy battery reading spirals down slowly. Brand new battery a week old. Duralast etx9
Post by jun on Jul 28, 2014 21:12:00 GMT -6
Sounds good guys! Thank you verymuch for your endless effort to help the ones in need..when i turn the ignition on with the battery hooked up brake light and head lights turn on. Same thing when the motor is running and the battery is diconected the lights are still working but dim. I blew my turn signal relay over revving it without a battery which is a stupid mistake lol.never again. Hope the gurus can come up with something for me...
