Post by barry on Oct 25, 2016 16:59:25 GMT -6
- How do you install hand guards on scooters..?
Post by barry on Oct 1, 2016 21:09:12 GMT -6
Post by barry on Sept 30, 2016 18:09:54 GMT -6
Still can't find how to remove body panels. But I did pull the top off the carburetor found the "Pop goes the Weasel" spring. There was a rubber type inner lining inside the top of the carb. At the bottom was a white kind of a almost sprocket looking thing. Should I spray Carburetor Cleaner down there..? Will it hurt the rubber liner or the white plastic thing at the bottom of the carb..? What do I do now..?
Post by barry on Sept 30, 2016 18:04:44 GMT -6
You can order it from many "Scooter Parts" stores here on line or I think you can still order them directly from Roketa.com .... There really not to hard to find.
Post by barry on Sept 25, 2016 14:22:55 GMT -6
Thanks, Where does the vacuum line end from the fuel pump..? The body panels have no outside screws showing. They must be taken off a different way...I think.
Post by barry on Sept 25, 2016 12:03:16 GMT -6
Thanks everybody, Got a new fuel pump installed but should have checked the old one since no gas is coming out as I crank the engine. Probably didn't need one. Couldn't reach the carb very well so I removed the line from the fuel pump that goes up to the carb, crank her over and nothing. So, could be vacuum or the carburetor.. Where does the vacuum line go from the fuel pump..? I'm having a real hard time getting to things. Have no idea how the body panels come off so I'm working from under the bike ( did remove the bottom panels to find the fuel filter) and from under the battery cover and the little removable access panel under the seat... not much room.
p.s. are fuel lines and vacuum lines different..?
Post by barry on Sept 24, 2016 21:22:13 GMT -6
Another question How do I check to see if there's fuel coming out of the fuel tank..? If I remove the incoming side of the fuel filter, will gas start flowing out..? Nothings getting to carb...
Post by barry on Sept 18, 2016 14:37:46 GMT -6
Thanks you guys, I'll try everything....
Post by barry on Sept 15, 2016 17:01:01 GMT -6
So in the process of replacing my air filter in my Jonway YY250T scooter, I found a 3"x4" piece of old lumber leaning against my red air filter . 1st time change air filter... weird.........
Post by barry on Sept 8, 2016 17:45:10 GMT -6
Now my scoot won't start ... or have I posted this already..? My 2011 Jonway YY250T (MC-54) turns over fine, in fact if I can't fix the problem soon I may need to buy a new battery. Anyway, my scoot turns over, just doesn't start. I figured it was maybe spark or fuel. I got some starter fluid and sprayed down the air filter and it started great, and ran fine until the starter fluid ran out. So, I know I have spark, maybe it's the fuel filter. After about an hour I finally found the fuel filter and installed a new one. Nothing, no help at all. Seems like gas isn't getting to the carb, but I don't know. I know very little mechanically and worried I'll get over my head if I don't get help........so, help thanks barry
Post by barry on Sept 3, 2016 11:03:31 GMT -6
Thanks bob, I've got the lower panel almost off. I have the front and back loose but there's something holding it underneth in the middle and I can't see what it is. NO more screws or bolts to remove. Nothing visible I can see and I'm worried about just pulling on it. Did you encounter this problem too..? How did you remove yours..?
Post by barry on Sept 2, 2016 15:20:33 GMT -6
Anyone know where the fuel filter is on a JONWAY 2011 YY250T..? And how to get to it....
Post by barry on Aug 17, 2016 14:50:31 GMT -6
My Jonway can turn over just fine, I smelled gas so I know it can flood. So starter is good, battery is good, gas is getting through. Anyone know where the sparkplug is..? How can I tell if it's getting spark..? What else could it be..? Where is the "fuel filter"..? Worked perfect till this morning...
So I guess I'm asking where is the sparkplug and the fuel filter are on 2011 Jonway YY250T thanks barry
Post by barry on Jul 26, 2016 18:28:37 GMT -6
Thanks Guys, the Trunk and saddle bags are from eBay. Also put a 12v plug in the glove box. All lights including dash lights are LED's( except head lights). Added a 10amp battery with 175 cranking amps. Changed out rollers for sliders and that's about it.
Post by barry on Jul 25, 2016 22:57:27 GMT -6
