Post by papagus on Aug 23, 2020 16:14:40 GMT -6
I have the same scooter i would like to install a 150cc engine any advice as to where to start
Post by papagus on Aug 28, 2018 9:32:35 GMT -6
Jim, is the man to call, he is all in when it comes for customer service 715 825 3710 he has help papa out give this man a call.
Post by papagus on Jun 21, 2018 20:55:40 GMT -6
Being an old tire dealer, one thing you can try over inflate your tires, by 15lbs over max inflate. ride on hot day as many miles you can take!!!! Let tires cool down refill to max psi. Your trike may have flat spots this some times will resolve the problem. Also do you use balance beads, or have them computer balanced. After all this try riding with less air pressure 5lbs.lower than max. Good day hope it helps.
Post by papagus on Apr 23, 2015 10:10:46 GMT -6
Good day, I have a 20013 jodway yy50QT-6 with 1200 miles on it I have changed all engine,gear oil my question is this do I need to service the Tran's if so how do I do this'.
