Post by mickyb01 on Mar 7, 2016 18:18:24 GMT -6
Ok so I checked the R/R and it checked good. I bought a new battery and started it up. The lights were on and bright. But when I increased the RPM's with the meter hooked to the battery the voltage didn't raise.
Post by mickyb01 on Mar 6, 2016 8:44:27 GMT -6
Post by mickyb01 on Mar 5, 2016 14:28:01 GMT -6
I ohm checked the stator again and it checked good. The last time I started it and shut it down, then went to restart it, I had nothing, not even dash lights. I checked the battery and it said 1.6v, so I put a charger on it, just waiting now. The battery was really weak to start with. I'm wondering if I need a new battery?
Post by mickyb01 on Mar 5, 2016 9:06:46 GMT -6
No, no green wire on the old stator
Post by mickyb01 on Mar 4, 2016 3:30:57 GMT -6
I already have that video, that's why I posted my last question. I told you the results. Are they normal? And why is the stator grounding out?
Post by mickyb01 on Mar 3, 2016 19:56:04 GMT -6
I om checked the stator and when I checked pin to pin the meter read 103 or better then dropped to Zero in all 3 checks. Then I checked for ground and it turned out to be grounded. I removed the black stiff wire from the cover and I still have a ground. I hope the pictures came through....
Post by mickyb01 on Mar 1, 2016 14:59:34 GMT -6
Hi, I started the scooter and checked the A/C voltage with the multimeter while it was running and I got 13.68 vac and when I reved it up to approximately 4000 rpm's it didn't change, still 13.68. Is this normal?
Post by mickyb01 on Feb 28, 2016 16:05:33 GMT -6
Ok, I finished putting it back together. After the cover was installed near the forward area of the cover there was a stiff black wire, I guess I wasn't paying attention when I removed the cover. I assume that this wire gets attached to the cover, from the way it was hanging. I'd like your thoughts on that. Also what is the recommended oil to use and where do I fill it up? Thanks for all of your help so far.
Post by mickyb01 on Feb 25, 2016 19:19:02 GMT -6
Ok, so I received the new stator and pick up coil. I don't remember how it came apart, do you have any pictures of what it is supposed to look like? I can take a picture and send it tmrw. Also what oil does it use?
Post by mickyb01 on Feb 21, 2016 15:55:44 GMT -6
I'll check tmrw, what about the coolant tube that comes out of the cover? It's the one that faces straight up...
Post by mickyb01 on Feb 20, 2016 20:46:24 GMT -6
Yes, that's it. Also I was gonna order a new cover but I can't find one with the hose end that is pressed into it. The old one is rusted pretty bad
Post by mickyb01 on Feb 16, 2016 12:53:57 GMT -6
Ok, I ordered everything I will need, but I can't find the chrome high pressure fuel tube.
Post by mickyb01 on Feb 15, 2016 17:39:57 GMT -6
What is your opinion, should I replace the pickup coil? If not how do I remove the wires from the gromet and insert the new wires in it?
Post by mickyb01 on Feb 15, 2016 14:36:09 GMT -6
It looks similar but it doesn't have the black box with 2 wires attached to it. Also is the stator supposed to be in oil?
Post by mickyb01 on Feb 14, 2016 18:37:04 GMT -6
I hope the picture helps, I can't locate a stator like mine (with the 4 yellow wires coming out of it. I'm talking about the odd one coming out of the side mickyb01 Alleyoop
