Post by joneck123 on Jul 24, 2015 1:57:38 GMT -6
This is a carryover from my post on the custom spacers I had made to work with the BaneBot motors I dropped in my son's PW F-150. Basically it's just some info I've collected on the more readily available 32 pitch, 16 tooth, 5mm bore pinions that are out there. Hopefully this helps someone out when it comes time for them to try their first upgrade! By the numbers the Castle and Axial pinions are identical, but there are significant differences. The Castle pinion is machined aluminum, very lightweight. The Axial pinion is powder steel, and the teeth are angled at the bottom. This leaves less surface area to engage with the spur (first) gear. Since these are all 32 pitch, 16 tooth you would think the teeth would be identical. However, as these top views show, there are slight differences between the manufacturers. At an angle you can better see that the top of the Novak pinion is hollowed out a bit, ostensibly for weight savings as these pinions are typically used in custom built RC cars. Thanks for reading, feel free to ask questions. Hop over to my spacer post to read about how to get perfect pinion placement on the BB775 motor shaft.
Post by joneck123 on Jul 3, 2015 21:14:58 GMT -6
Post by joneck123 on Jul 2, 2015 2:50:06 GMT -6
Hey guys I recently discovered this " automatic motorcycle scooter hybrid " Does anyone have one and what do they think? I'd be upgrading from a 50cc Chinese scoot which ive had to learn how to repair myself so I'm wary about another Chinese scoot but I love the price and the looks of it. I heard its hard to find parts for it. If you have one tell me what you think, where you got it, and where you find your parts. I can't even find a manual online for it. The ones that say they go to it lead me to a 50cc scoot that look nothing like it. thanks!
Post by joneck123 on Jul 1, 2015 2:19:04 GMT -6
it's that your house? vevy nice.
Post by joneck123 on Jul 1, 2015 2:13:40 GMT -6
it's very good post,i need Rich's video
