Post by metalburner on Sept 23, 2016 21:11:48 GMT -6
Found the problem loose wire thanks
Post by metalburner on Sept 23, 2016 11:49:53 GMT -6
Bike is running great but my gas gauge quit working,any ideas about what it could be? Thanks.
Post by metalburner on Apr 27, 2016 16:55:03 GMT -6
Thanks for the tip got it apart today waiting for new bearings from eagle atv update to follow.and i'm not scared of girls just spiders and the i.r.s. lol
Post by metalburner on Apr 26, 2016 21:26:28 GMT -6
Got a grinding noise when i back of the throttle and side to side play in the wheel its a taotao powermax 150
Post by metalburner on Apr 26, 2016 16:51:33 GMT -6
I think my rear wheel bearing is going out lots of play in it anyone changed one of these before? Grateful for any tips its a powermax 150 by taotao.
Post by metalburner on Apr 26, 2016 16:50:32 GMT -6
I think my rear wheel bearing is going out lots of play in it anyone changed one of these before? Grateful for any tips.
Post by metalburner on Mar 22, 2016 22:12:23 GMT -6
Found the problem a couple of my rollers were damaged running great now thanks.
Post by metalburner on Mar 22, 2016 9:56:29 GMT -6
Just replaced my clutch,variator,and belt now it seems my bike won't go into high gear about to set fire to this thing.
Post by metalburner on Mar 7, 2016 17:26:52 GMT -6
Thanks guys i'm making arrangements to borrow an impact wrench.
Post by metalburner on Mar 7, 2016 11:03:34 GMT -6
I have been trying to remove the variator from my scooter for a while with no luck i have purchased a holding tool applied deep creep lubricant,heat and a 25 inch breaker bar all with no luck,anyone have an idea or tip? Thanks.
Post by metalburner on Feb 4, 2016 15:07:27 GMT -6
Thanks for your help just ordered a new belt and clutch
Post by metalburner on Feb 3, 2016 18:28:22 GMT -6
How can i tell if my clutch is going bad what are the symptoms? My bike shakes at idle and my drive belt is chewed up any thoughts? Thanks
Post by metalburner on Dec 30, 2015 13:46:06 GMT -6
Thanks
Post by metalburner on Dec 30, 2015 13:03:15 GMT -6
My scooter began missing replaced the plug which helped then it got worse it misses and bogs down. Any ideas it has 3,700 miles.
