Post by redrocker1 on Jan 28, 2012 9:56:40 GMT -6
January 28th. 2012.
sprocket helped me with the SAME PROBLEM that you are having!
The petcock was TOO high on the frame to allow fuel to the carb. And I used an after market (larger) fuel filters! I lowered the petcock to the bolt for the inner fender mount. I replaced the larger filters with the smaller stock fuel filters.
2000 miles and has not failed me once!
Larry Johnson (redrocker1) homeloanrealty@yahoo.com
Post by redrocker1 on Nov 8, 2011 6:33:04 GMT -6
I am thinking about this windshield for both of our Roketa 150's www.scrappydogscooters.com/Universal scooter windshield Just in time for inclement weather. Universal scooter windshield fits just about any scoot by mounting on the mirror tabs. Strong and easy installation. Quality clear plastic shield is easy to clean and maintain. You won't find a price this low even on Ebay! $29.95 complete with shield and all mounting hardware. REDROCKER1
Post by redrocker1 on Apr 13, 2011 22:30:13 GMT -6
April13th. 2011 @ 11:30 P.M.C.D.T.
I had this problem on a 90 cc Honda.
Both intake and exhaust valve adjusting screws and lock nuts
were out of the rocker arms and laying in the rocker box!
I adjusted the valves per the Honda repair manual AND presto!
after 3 kicks it started and ran perfect.
With both valves closed YOU will break the kick starrter shaft!
redrocker1
Post by redrocker1 on Mar 26, 2011 11:39:05 GMT -6
March 26th. 2011
Are gelcell batteries better? Do they make a gelcell that fits in floor compartment? I really like this tech discussion. redrocker1
Post by redrocker1 on Mar 22, 2011 16:32:50 GMT -6
March 22nd 2011
I connected a 2 amp trickle charger to my BRAND new Roketa MC-75-150 and FOUND the NEGATIVE fuse (GROUND) broken! NOT BLOWN! Starter/lights out NO start! I checked both battery fuse's and I replaced the fuse with the one in the fuse holder and presto it started! Check your ground fuse on the battery ground! redrocker1
Post by redrocker1 on Mar 22, 2011 16:18:04 GMT -6
Hello everyone, Need to find Part#/ where to buy UNI/K&N filter for Roketa MC-75-150K and MC-75-150?
Do I need to rejet low and high speed jets?
Thank you redrocker1
