Post by flexo6 on Jun 2, 2013 11:19:34 GMT -6
Thanks Guys....It was the fuse...I know better then to check a fuse while still in...but thats what I did...DUH!...Thanks again
Post by flexo6 on Jun 1, 2013 13:14:47 GMT -6
Wife went to start her 150cc gy6....nothing electrical works at all.....battery is good ...fuse is good....Im getting 14v up to the selonoid....anyone have any ideas? I know mechanical side of these things but need to brush up on electrical side....if it would be the voltage regulator....is that up in the steering cover? No light ,turn signals horn,brakelight.......nothing and it don't tur over at all?...any help is very much appreciated!
Post by flexo6 on Apr 15, 2013 13:37:51 GMT -6
Thats what I question too, how can you know the exhaust valve is burnt? Unless it is apart there is no way to be sure. Head is off...its burnt
Post by flexo6 on Apr 15, 2013 13:37:17 GMT -6
Just because you lost compression does not mean the valve is burnt. To say it is burnt you actually have to take the head off and look at it. It could just be that the EXHAUST valve is tight an needs to be adjusted and is staying a little open therefore loss of compression. So first check the valve adjustment and adjust the Valves: for 50cc INTAKE .003 inchs and .004inchs EXHAUST for a 150+cc INTAKE .004 inchs and EXHAUST .005 inchs. THEN CHECK your compression again. Alleyoop Head is off...and its burnt
Post by flexo6 on Apr 15, 2013 13:36:19 GMT -6
Backing the A/F screw out adds fuel to the low speed circuit. I really doubt that burned up your exhaust valve. The main jet is what makes it run lean or rich. Also adjusting the needle up or down can affect that. How do you know it's burnt, are you able to visually inspect it. If you had a leak at the exhaust port that was letting air to get to the valve it can warp it and boom...compression loss. What was your compression on the dial by the way? Checked compression..it was 30...took apart...definetly burnt....no exhaust leak.
Post by flexo6 on Apr 14, 2013 15:29:21 GMT -6
Lost compression..did a compression test. Exhaust valve is burnt. What do you thik I should check?....When adjusting fuel/air mixture screw....does turning it in give it more air or more gas? Before I replace valve do you think I should up the jet some? Spark plug didn't look all that bad color wise. Thanks for any input!
Post by flexo6 on Jul 18, 2011 17:30:43 GMT -6
Standard Bolt Local bolt guy? They aren't available on the internet I have access to over 100 parts suppliers for GY6 engines...... OK...Thx Sproc!
Post by flexo6 on Jul 17, 2011 17:36:25 GMT -6
Anyone know where to get these head bolts....2 at the cam chain side... for a gy6 150cc..... Attachments:
Post by flexo6 on May 6, 2011 17:22:03 GMT -6
No to the JB weld....find a welder.
Post by flexo6 on May 2, 2011 18:05:07 GMT -6
Yep....got it...it was a bad stator! Thanks guys!
Post by flexo6 on Apr 27, 2011 17:19:23 GMT -6
What would make a new stator go bad? I had very weak spark...traced it down to the stator. I put a new stator in and was getting really good spark for a few days..and now getting nothing. I am getting around 49 volts at the red and black wire coming from the stator. I never was getting up to the 85 volts like I read on other posts what I should be getting. I did voltage tests at other spots and all seemed fine...I even swapped cdi's and coils and a new flywheel and still nothing. Any idea's would be greatly appreciated! I have a feeling I got a bad stator ...only because I never did get the voltage I should have. Do ya think it might have took a crap?
