Post by geh4444 on Apr 28, 2024 14:12:54 GMT -6
55 is normal for a 150cc, but a redline at 7500 is a little low. I think they usually redline at 8000+
Post by geh4444 on Apr 13, 2024 22:46:26 GMT -6
Does the starter turn over ?
Post by geh4444 on Apr 13, 2024 22:43:36 GMT -6
Trying to send a pic ![](https://hosting.photobucket.com/images/t662/geh3333/IMG_2024-04-13-21-14-43-545.jpg?width=320&height=320&fit=bounds)
Post by geh4444 on Apr 13, 2024 22:35:10 GMT -6
I got a kit from drowsports and the cylinder studs are too long !! The kit should not need a spacer and the timing chain supports this also. The chain fits perfect , not loose but I have to add washers to tighten down the head nuts and the valve cover will not fit be ause there is too much stud sticking out . Also I have the 67mm kit of course , b case , but the head says " use with 63mm " ?? So possibly the wrong head ?? I just emailed the place I got it from , so we will see. But any info will help .
Post by geh4444 on May 10, 2023 20:09:00 GMT -6
I actually have 2 of them . I'll put a couple pics up. But I run an 842 belt which u can only fit on a long case. And I highly doubt the 14 inch wheels would fit on a short cade engine .
Post by geh4444 on May 10, 2023 20:04:37 GMT -6
I have a spark 150, it has a long case not a short case
63mm BBK
by: geh4444 - Sept 26, 2022 1:22:40 GMT -6
via mobile
Post by geh4444 on Sept 26, 2022 1:22:40 GMT -6
Got the 63mm kit and head installed. I bored the case out with files and grinding wheels . I went for a short ride . I have an oil leak either from the variator side crank seal or its coming from the valve cover . I may not have tightened it down enough. It was 2am so ill check it in the morn. The scoot ran great and felt really strong. I have 18:36 gears in at the moment . I should be able to turn them with the extra hp from the 63mm kit. Hoping to be able to hit 70mph easy , possibly 75 top speed or higher.
Which OIL.
by: geh4444 - Sept 5, 2022 18:11:21 GMT -6
via mobile
Post by geh4444 on Sept 5, 2022 18:11:21 GMT -6
I like 10w40 royal purple max cycle
Post by geh4444 on Sept 5, 2022 18:07:51 GMT -6
Id imagine possibly only the fuel lines and the needle valve. Possibly the float. Only bc they are rubber and plastic. But everything may be ok
63mm BBK
by: geh4444 - Sept 5, 2022 18:05:56 GMT -6
via mobile
Post by geh4444 on Sept 5, 2022 18:05:56 GMT -6
Anyone install a 63mm kit ?
Post by geh4444 on Sept 5, 2022 18:04:58 GMT -6
Well after 3 blown top ends i figured out a couple issues . One being a bent and twisted pitson rod. So i oredered a new crank and 63mm top end . I bored the case out myself with a few dif files and im awaiting all the parts. The crank is here and the top end " cylinder and head " will b here 2mro. The gasket set and new rocker arm assembly might b here 2mro. Cant wait
Post by geh4444 on Jul 21, 2022 16:52:20 GMT -6
Yeah all the old sites seem dead
Post by geh4444 on Jul 21, 2022 16:50:52 GMT -6
Yes it turns clockwise however it should be able to turn counter clockwise although i dont really recommend it.
Post by geh4444 on Jul 21, 2022 16:48:23 GMT -6
Everything is grounded properly?
Post by geh4444 on Jul 21, 2022 16:47:25 GMT -6
How are your valves adjusted and are u sure its in time ?
