Post by carlster2011 on Sept 28, 2011 11:39:10 GMT -6
Hi one and all, I'm back again. I did a valve adjustment on my 150cc scooter, it ran fine the rest of the day, all day and this morning it would start. Any ideas. It does start if I use starter fluid but then dies when it runs out of spray. I'm thinking it may not have anything to do with the valve adjustment cause it starts and runs good when I use the starter spray. Any thoughts?
Fuel gauge
by: carlster2011 - Sept 18, 2011 23:25:36 GMT -6
Post by carlster2011 on Sept 18, 2011 23:25:36 GMT -6
Ok, sounds great. I'll give that a try first and let you know how it works out, probably toward the end of the week. Thanks again.
Fuel gauge
by: carlster2011 - Sept 18, 2011 22:17:14 GMT -6
Post by carlster2011 on Sept 18, 2011 22:17:14 GMT -6
Thanks, once again this has been the most helpful site on this issue, you guys are the greatest. Do you think a cork screw from a bottle of wine would be a good replacement for the float or would the gas just dissolve it? I have heard this idea before and it sounds like a good idea, any thought on that? Thanks again.
Fuel gauge
by: carlster2011 - Sept 18, 2011 21:39:20 GMT -6
Post by carlster2011 on Sept 18, 2011 21:39:20 GMT -6
Hi guys, Carlster again. Lately my fuel gauge seems to be acting up. When it runs low on gas and I add more the gauge seems to be stuck where it was when I added the gas even when I know its full. Some times it seems after I hit a few pumps in the road it will go up to where it should be. It seems as though the floater thing maybe getting stuck. Is there a quick fix for this that anyone may know of? I'd hate to have to keep going over pumps on purpose just to see how much gas I have, lol. Also wiggling the bike back and fore a bit seems to get it on stuck as well. Its a 150cc Chinese Roketa with the fuel tank on the floor board just behind and in between where your feet rest while riding. Thanks in advance for any help anyone has to offer.
Fuel filter
by: carlster2011 - Aug 6, 2011 11:58:43 GMT -6
Post by carlster2011 on Aug 6, 2011 11:58:43 GMT -6
My gas tank is below the foot board between the seat and front steering stuff, would it have a petcock or just the tank?
Fuel filter
by: carlster2011 - Aug 6, 2011 10:40:32 GMT -6
Post by carlster2011 on Aug 6, 2011 10:40:32 GMT -6
Hi again scooter docs, I have one more question if you guys don't mind. Is it normal for the fuel filter to empty when the throttle is opened? I noticed when I had mine on the center stand and running, that when I opened the throttle to give it a good rev. the filter looks like it would empty but then fill right back up when I released the throttle. I'm thinking wouldn't this cause a problem if I was to ride near top speed for more then a few minutes? I am new to the whole scooter seen and this website has helped me a great deal. I really do appreciate all the helpful advice you guys have been able to give me. I'm hoping that this will be my last question for a while.
MC-16K-150
by: carlster2011 - Aug 4, 2011 8:53:23 GMT -6
Post by carlster2011 on Aug 4, 2011 8:53:23 GMT -6
Yeah, you wouldn't think there would be stuff in the tank, and in my case the thing is only like 2 weeks old with less then 200, miles on it. Its been acting funny since the day I got it though. But at least now the valves are set, the carburetor is extremely clean, the fuel mixture is great and the idle is right where it should be. I'm going out now to change the lines and see if I can find any thing in the tank. This is a really great website that I wish I had discovered earlier, could have saved a lot of time and effort (and gotten stuck here and there a lot less). Thanks to everyone one for all the helpful advice.
MC-16K-150
by: carlster2011 - Aug 3, 2011 19:01:29 GMT -6
Post by carlster2011 on Aug 3, 2011 19:01:29 GMT -6
Lol. Thanks Sprocket. I'll do a condom check in the am.
MC-16K-150
by: carlster2011 - Aug 3, 2011 15:53:50 GMT -6
Post by carlster2011 on Aug 3, 2011 15:53:50 GMT -6
Is there just the one line between the filter and the tank? It looks like that's it, but I'm not sure because its hard to see beyond that without taking a crap load of body stuff off.
MC-16K-150
by: carlster2011 - Aug 3, 2011 15:33:48 GMT -6
Post by carlster2011 on Aug 3, 2011 15:33:48 GMT -6
Thanks for all the great advice guys. I've narrowed it down to something between the gas in the tank and the fuel filter. After cleaning the carb, adjusting the values, setting the idle speed and adjusting the fuel mixture it happened again, so what I did is I reinspected the line again and there didn't appear to be anything wrong. So I removed the gas line from the filter and just stuck it into a small glass with gas in it (after killing the battery twice trying to get it to start) and after only two or three seconds it started right up, I was amazed and happy. Next I took the filter off and blow it out from both sides with a compressor. I let the engine run out of gas by taking the line out of the glass (which I was surprised at how long it took to finally run out) then I reattached the filter and the same thing 2-3 secs and it started no problem which is better then usual. So I again let it run out of gas and then reconnected everything. It Started and run for about 2 mins if that and it shut off again, and then would not start no matter what I did. So I disconnected the line again with the filter still attached and put it back in the glass of gas, and wouldn't ya know it 2-3 seconds it fired right up with a weak battery and run great this time I let it idle for a good 20 mins no problems I even tried to see if I could get it to stall out, it wouldn't which it normally would have after idling for that long. So that's where I'm at. I had to stop for dinner. It seems to me that the problem lies somewhere between the fuel filter and the gas in the tank. Any ideas? And thank you all again for the great advice. You guys really seem to know your stuff.
MC-16K-150
by: carlster2011 - Aug 3, 2011 11:33:32 GMT -6
Post by carlster2011 on Aug 3, 2011 11:33:32 GMT -6
Thanks for responding to my message. I check the houses and they seem to be clear. I had it running and it was running good like it does and then it happened again it just stopped. This time I'm out of starter fluid (I ran out) so I couldn't get it going again. I'm charging the battery and I'll try it in just a bit. Thank you again again for responding. I'll keep you updated.
MC-16K-150
by: carlster2011 - Aug 3, 2011 9:16:06 GMT -6
Post by carlster2011 on Aug 3, 2011 9:16:06 GMT -6
Hi everyone, I'm new here. I'm glad I was able to find this site, it seems like it can be very helpful. I have just got a new scooter and I'm having issues with it right off the bat. After going through everything and tightening up many nuts and bolts and replacing the headlight (already, because the one from the factory was wired wrong and caught on fire after about 15 mins after I finally got it started). At this point I must say that I'm not enjoying my new scooter at all. Any way I beleive I have worked out all of the numerous minor "kinks" there is still one that I haven't quite work out yet. It will start ok and run good, but at random times usually when idling or once at about 5 mph it just stops, no sputtering or anything, just like turns off. When this happens it is incredibly difficult to restart. I usually have to give it a skirt or two of starter fluid.Once it starts again it seems to run fine until the next time it happens and then its the same thing. I can only get it started with a few skirts of starter fluid. If its running good and I turn it off it seems to restart just fine. I'm beginning to get very frustrated with it because its unpredictable as far as when this will happen and considering its brand new I've been stuck quite a few time (I now carry the can of starter fluid as part of my tool kit). If I could just get this worked out so that its reliable and I wouldn't have to be worried about getting stuck everywhere I would be so happy with it. It's a : KAIT MC-16K-150 So far I must say I'm not to impressed with it. My other question is there is a clear hose in the engine compartment that I have no idea what it does or if it my be part of the problem. When it was running I removed the plug that was in the end and it almost seemed to run better (or it was just a coincident, like I mentioned when it running in run very well). I'll try to add a picture of the hose I'm talking about. Any help or advice anyone can give me would be very greatly appreciated. I'd really like to start enjoying it instead of getting headaches with it.
Post by carlster2011 on Aug 2, 2011 14:43:47 GMT -6
Hi Cruisethescoot, I seem to be having the same problem with one I just got maybe a week or to ago. For the most part it seems to run good then all the sudden, usually when its idling it just stops and then it next to impossible to get it running again. I usually have to give it a few skirts of starter fluid. One I get it going it seems to run fine until the next time. I can't think of any cowmen thing that happens at the time. It seems to just be random. After checking hoses, carb.(I even gave it a good cleaning), and carb adjusting when its running it seems to run good then all of a sudden (usually at a lower Idle) it just stalks out and is almost impossible to start again (I usually have to give it a skirt of starter fluid) then once its running it seems fine until the next time. I too am stumped. The thing that surprises me the most is that it is a brand new 2011 made in May and I received at the end of July. I would think something that new should be just a tad more reliable. I you figure it out let me know, I am also stumped as far as what could be causing this.
