Senior Clinician
Post by raford3 on Jan 7, 2012 15:44:53 GMT -6
Oh those kickstands typically have to be cut to length.
Senior Clinician
Post by raford3 on Jan 7, 2012 15:42:45 GMT -6
About the best thing that could have happened to it is if the timing chain took it to the crankcase, then don't worry be happy as it might get stuck in the filter area but shouldn't hurt anything riding the bottom of the crankcase.
Senior Clinician
Post by raford3 on Jan 7, 2012 15:32:52 GMT -6
Get your eye down almost at the level of the concrete and look around really good you may be able to see it like that. I can't see it getting by the valve and into the combustion chamber but if it did I'd just hope it didn't beat up the piston too bad. Look really hard, does anybody have a metal detector, ask your neighbors.
Senior Clinician
Post by raford3 on Dec 30, 2011 16:32:52 GMT -6
Now you need to take the old carb apart to see if you can locate the problem it had and you may need it for spare parts.
Senior Clinician
Post by raford3 on Dec 30, 2011 15:01:22 GMT -6
Gotta go ride the bicycle it's 60 outside.
Senior Clinician
Post by raford3 on Dec 30, 2011 14:56:47 GMT -6
A good rule of thumb is never should an adjustment be at either extreme.
Senior Clinician
Post by raford3 on Dec 30, 2011 14:53:51 GMT -6
Alleyoop meant to say tighten it at the carb so you can loosen it on the handlebar.
Senior Clinician
Post by raford3 on Dec 30, 2011 14:36:32 GMT -6
You need to show 3 threads on the adjuster on your carb so you can get to a happy place with the 1 on the handlebar which is beyond it's range.
Senior Clinician
Post by raford3 on Dec 30, 2011 14:21:44 GMT -6
It might just start right up 'cause you don't need vacuum to open your petcck
Senior Clinician
Post by raford3 on Dec 30, 2011 14:19:23 GMT -6
Same amount but do it a lot don't just crank it when it's not firing.
Senior Clinician
Post by raford3 on Dec 30, 2011 14:16:49 GMT -6
We have dudes playing sheet rock mud buckets in Richmond. I don't know how they get different tones from them but some are quite good at it.
Senior Clinician
Post by raford3 on Dec 30, 2011 14:05:17 GMT -6
Next time you see a homeless person playing a guitar on the side of the road give him a good tip and get the scraps he cuts off his strings.
Senior Clinician
Post by raford3 on Dec 30, 2011 13:58:22 GMT -6
I was hitch hiking in Arizona and was crossing the Navajo reservation. I must of gotten 20 rides with indians who were curious why I was there. Navajos have round looking faces and look very friendly. I got a ride with an Apache and he had a much narrower face, not as happy or friendly looking.
Senior Clinician
Post by raford3 on Dec 30, 2011 13:51:06 GMT -6
Main jet was your problem with the old carb.
Senior Clinician
Post by raford3 on Dec 30, 2011 13:42:32 GMT -6
I knew a dude who was in Vietnam and he could tell a Vietnamese from a Chinese or a Korean. He said the faces have different features.
