Post by new2scoots on Apr 14, 2012 13:20:11 GMT -6
btw, I'll be selling the new 8 coil stator and rotor if anyone is interested. I'll post it in the for sale section later. Thanks!
Post by new2scoots on Apr 12, 2012 11:27:24 GMT -6
Going back to a 6 coil stator with the 4 pin regulator worked. Scooter runs great now! Thanks again for pointing out the floating ground on the 8 coil stator. That was definitely my problem. Ride safe!
Post by new2scoots on Apr 6, 2012 9:08:31 GMT -6
Thanks Silverfox. That's what I suspected. So, is it safe to assume the regulators I have are bad or do you think they will still work with the 6 pole stator? Thank you.
Post by new2scoots on Apr 6, 2012 4:48:03 GMT -6
How much voltage should be going to the plugs for the lights in a 6 coil vs. 8 coil setup. I was seeing over 90 volts with the 8 coil setup (no lights connected, so no load distribution).
Post by new2scoots on Apr 5, 2012 15:08:30 GMT -6
Out of curiosity, I'm a bit confused when I hear people say to get a 7 pin regulator. My harness doesn't have a 7 pin plug (it only has the 4 pin plug). Am I missing something?
Post by new2scoots on Apr 5, 2012 7:48:56 GMT -6
Thanks Alley, but I'm going to try to bring it back to original working condition first.
John, I have already ordered a new 6 pole stator, but if I need anything else, I will let you know. Thank you!
Post by new2scoots on Apr 4, 2012 19:32:01 GMT -6
Thank you very much! I will order a new 6 pole stator. Much appreciated!
Post by new2scoots on Apr 4, 2012 19:12:50 GMT -6
Post by new2scoots on Apr 4, 2012 16:03:17 GMT -6
Hello everyone, I'm looking for some help with replacing my stator. I'm working on a 150cc Longbo scooter that wasn't starting and it turned out to be the stator. It originally came with a 6 pole stator and I replaced it with an 8 coil. The scooter now starts, but blows headlights. I've tried three regulators and still have the problem. I just performed an additional test on the stator itself and noticed there is no coil resistance except between the white and yellow wires. If I understand correctly, there should be resistance between white and ground, as well as between yellow and ground, but I get "OL" on my meter when I test those.
In short, I have two questions:
1. Could the fact that there's no coil resistance be the cause of the excessive power blowing the headlights?
2. Is there a difference between an 8 coil stator and a 6 coil stator where the 8 coil is supplying significantly more power and therefore blowing the headlights?
I'm wondering if I should just look for another 6 pole stator to try instead of another 8.
Post by new2scoots on Apr 1, 2012 11:04:25 GMT -6
I'm working on my brother's scooter (Longbo 150cc), which also has an overcharging problem (and blowing headlights) and after replacing a few electronic components and having two bad regulators, I decided to check the wiring once more. Turns out I had a short. The yellow wire going from the stator to the regulator had continuity with ground. I didn't think that was good so I 'unwrapped' all the wires in the harness and looked for damaged wires. I found some bundles of yellow wires soldered together which led to check what they all branched out to. I discovered that unplugging the enricher solved my problem. I checked continuity between the two terminals on the enricher plug and it was present, so it appears there's a short in my enriched wiring. I ordered a new enricher and regulator so I'll know for sure when they come in.
Quick question, this scooter has a center light in the front that uses a small bulb, similar to the license plate bulb. The bulb holder was rubber that hardened and broke so it no longer holds the bulb. I decided to just disconnect it. Do you think that alone will decrease the load enough to cause problems? I wouldn't think so, but if it does, perhaps adding one of these resistors would help. The scooter didn't come with one originally. Then again, it was bought second hand so I don't really know for sure.
