Post by lazerorca on Apr 23, 2012 17:39:26 GMT -6
this is what it is looking like now. I have torn some of the seal all to hell
Post by lazerorca on Apr 23, 2012 10:39:45 GMT -6
trying it with a tiny straight screwdriver from an eyeglasses kit... it isn't budging :-(
Post by lazerorca on Mar 17, 2012 18:14:11 GMT -6
yeah I moved the c clamp down on the needle on the diaphragm in the vac chamber... it is actually going substantially faster... but the low end is hesitating a bit. I will rock this until I get my new carb... it is coming in the mail.
Post by lazerorca on Mar 17, 2012 14:09:07 GMT -6
it would give me great pleasure to take a sledgehammer to this piece of crap at the moment haha... for 3 weeks or so it has been one thing after another... I hit this pothole on the way back from the store that had my bulb for my headlamp
Post by lazerorca on Mar 17, 2012 14:02:30 GMT -6
so how do I get the enricher out??? because if it involves unscrewing those 2 screws at the top... I just tried it... and one of them is stripped... as the case seems to be with a lot of screws on this scooter ugh.
Post by lazerorca on Mar 17, 2012 13:47:55 GMT -6
right now I have both wires not spliced... I tried it both with the wires spliced and without... got the same result... engine slows down and cuts off after about half throttle
Post by lazerorca on Mar 17, 2012 13:35:06 GMT -6
at full throttle... the only thing I found that was odd was when I lifted my seat, the yellow wire from the choke had come loose... I spliced it back together and still the same results
Post by lazerorca on Mar 7, 2012 19:47:20 GMT -6
balast resistors?
Post by lazerorca on Mar 7, 2012 19:06:45 GMT -6
Post by lazerorca on Mar 7, 2012 18:56:18 GMT -6
they light up but don't blink... I'm pretty sure I have it hooked up correctly. They weren't blinking before i put the new wiring harness in... when I got the scooter they were blinking
Post by lazerorca on Mar 7, 2012 15:17:13 GMT -6
the regulator is a good distance away from anything hot... any idea as to what else may be causing this?
Post by lazerorca on Mar 7, 2012 15:06:00 GMT -6
any clue as to what may be causing this besides a bad regulator possibly?
Post by lazerorca on Mar 5, 2012 12:09:27 GMT -6
I believe fuschia = red... right side of the handle bar has the starter button and the switch for killing the engine... we have red/yellow, green, black/white, black left side: hi/lo beam, horn, turn signal light blue, dark green, gray, black, orange, light green (i'd also like to note that dark green is matched with yellow on the other side of the connector...) both sets of brake wires are brought together to one set... green/yellow, black I finally have some photos This is from my new harness I believe they are the bundle of wires that goes to my ignition Here is a picture of the back of my ignition... Here is a pic of the back of the scooter where the harness hooks into the back harness for taillights, fuel sensor, etc etc.. Notice that orange and light blue have no match... I do have 2 unmatched bundles from my new main harness... they are (light blue and green) and (orange and green) wasn't sure if I should just match them and what I should do with the leftover green wires... Here is a pic of the wires for the stator... notice that there is a three pronged connector with yellow, white, and green while the connector from my new harness just has yellow and white This is a pic of the CDI. There is no black/white kill... it is replaced by another wire it is replaced by another wire (I believe red/white) This is a pic of the coil... i believe it is hooked up correctly These two wires I am a bit unclear as to their purpose... if someone would clue me in that would rock. I believe this goes to the voltage regulator. I'm not sure if I'm supposed to strap that green wire I'm holding to the body of the scooter. also the voltage regulator was originally mounted up front. This is a pic of the battery and starter relay... I think it is hooked up correctly This is the quagmire of sh*t on the other end of my harness This is what I somehow have to figure out where to hook up everything to the front end harness.. This is horn and blinker unit (and where regulator used to be)... and a gismo I'm unsure of below the blinker unit that has a braided white a black wire with bullet ends... This is a pic from behind the instrumentation panel I hope these photos are helpful... if you need more photos just lemme know. I can also shoot video.
Post by lazerorca on Mar 4, 2012 18:46:06 GMT -6
starting from rear... with the lights... green, yellow/white, blue/white match up to a plug, so does green, yellow/green, brown... on the harness I have 2 bundles left... (green, light blue), (orange, green) the bundle left from the back harness is (light blue, orange)...
to the CDI I have fuschia/black, fuschia/white, green/fuschia, yellow/blue, and green... I just plugged them in assuming they were in the right config
to the choke I have yellow, and green/black which matched up to my harness...
to the coil I have fuschia/green and green
now to the stator... what I have on the harness doesn't match cleanly... I have blue/yellow matched to fushia/white and fuschia/black to fushia/black... the plug from the harness only have yellow and white while the plug from the stator has white, yellow, and green...
I have a random plug that I haven't found a match to... it is a fat red/white wire... it comes from the start relay I believe... I also have wire that is green/black... doesn't match to anything either...
I believe this next plug goes to the regulator which originally was mounted on the front of my scooter... it is red, white, yellow, green... has a seperate green wire coming from it as well that I think is a ground wire... to the starter relay I have a fat red/white and fat red wire hooked up... also a red/yellow, and green yellow hooked up... that is all that I have hooked up...
here is what I have at the end of my harness to hook to the front end harness... listed by how they are bundled...
1. light blue, black 2. green, orange 3. light blue, green 4. green/yellow, black 5. green/yellow, black 6. green, white, blue 7. white, blue on one connector and green, light blue, blue, brown, orange, blue/black 8. on a blue connector, I have red/yellow, blue/black, black, brown, yellow, green 9. on a male connector I have blue, blue/white, light blue, orange, yellow/white, brown, black... with a separate green... I suspect this is the one I will need to use now sure... 10. I think this goes to the starter... fuschia/white, red, green, black
coming from the front end harness... here are the wires that need to be matched up... 1. on one connector I have blue/white, green, light blue, red/yellow, orange, black, yellow/white, and yellow... on a separate connector I have green and black/white... then there is another connector where the old harness had a green/black wire hooked to it... I have no clue what it is... the wires are running to this gismo have braided covering... they are black and white and run up close to the horn
Post by lazerorca on Mar 2, 2012 10:37:47 GMT -6
50cc Taizhou Chuanl
