Post by justlasvegaslisa on May 20, 2012 13:48:59 GMT -6
i went ahead and just installed the new starter using the old wiring, need to charge my battery a bit then hope for the best
Post by justlasvegaslisa on May 20, 2012 12:59:01 GMT -6
here is a better picture of the new starter Attachments:
Post by justlasvegaslisa on May 20, 2012 12:53:09 GMT -6
this is the new connection that goes to the relay Attachments:
Post by justlasvegaslisa on May 20, 2012 12:51:53 GMT -6
this is the old starter connection (on top) Attachments:
Post by justlasvegaslisa on May 20, 2012 12:31:20 GMT -6
I am replacing my old starter motor, and even though I double checked to make sure I purchased the correct starter unfortunately the wire connection to the relay is different then the old one. Can I use the old wiring with the new starter motor?
Post by justlasvegaslisa on Apr 5, 2012 6:47:27 GMT -6
I am having the exact same problem, I took my battery to a battery shop to purchase a new battery but the looked at mine and said "battery is fine," but still my scooter is just a clickin, purchased a voltage meter, it read 13.1 on my battery? Well I found out the only for sure way to know if the battery is good or not is to take it to a shop and get a load test on the battery. Takes 15 minutes at most. After I did this I learned my battery was in fact shot
Post by justlasvegaslisa on Apr 2, 2012 16:54:26 GMT -6
soo check gaps, and break switch! any idea about these hoses? [img src="[/img]https://picasaweb.google.com/lh/photo/05zuE_UUbX4483oGzisL-WzVKq3JPFKz51mHF0p4kpo?feat=directlink "] [img src="[/img]https://lh5.googleusercontent.com/-I5cLNKxL9yE/T3onPCHS6QI/AAAAAAAABMI/LUp2MbiSiCo/s144/DSC00037.JPG "]
Post by justlasvegaslisa on Apr 2, 2012 16:49:55 GMT -6
I took it to Shelton Battery in LV, a load test? I dont know. They are suppose to be battery experts.The battery reads a full charge?
Post by justlasvegaslisa on Apr 2, 2012 15:40:23 GMT -6
It is a taotao ATM50-A1 49cc, that was powered up and had a 100 cc motor put in it
Post by justlasvegaslisa on Apr 2, 2012 15:00:57 GMT -6
yes
Post by justlasvegaslisa on Apr 2, 2012 14:26:26 GMT -6
I am having a hard time attaching more then 1 photo
Post by justlasvegaslisa on Apr 2, 2012 14:14:48 GMT -6
[img src="[/imghttps://lh5.googleusercontent.com/-I5cLNKxL9yE/T3onPCHS6QI/AAAAAAAABMI/LUp2MbiSiCo/s512/DSC00037.JPG] "]Just purchased my first (used) scooter. The first night I owned it, I left the lights on all night. I have charges and taken the battery have checked, its fully charged. I cannot kickstart it and when I try to start the engine I get nothing but a click from the relay. I checked the wires, I have good voltage coming out of the relay but none going in, all the other wires, starter, motor, etc have voltage. The only other wire w/ out a reading is a black/white wire that connects to the CDI. Also is there suppose to be two spark plugs? I have a picture included Attachments:
