Post by ratrod on May 29, 2012 17:09:22 GMT -6
I am wanting a new Zuma and can still get ahold of one of the 2 strokes and have rode them plenty but can someone tell me how the 4 stroke runs and rides in comparison, Thanks,
Post by ratrod on Apr 24, 2012 21:40:06 GMT -6
I had the exact same thing on a new one a month ago. Mine was drawing a vacuum in the gas tank and would prevent fuel from flowing. On the tank vent side rubber hose there was an apparent check valve that looked to prevent fuel from leaking out if the bike fell over as it worked when up right but not inverted. I like the keep it simple idea so i just eliminated it and run my vent line down and away and left it unobstructed to atmosphere, end of problens, a quick test is to pull the gas cap off as soon as it stops and see if there is an inrush of air to determine if this is the solution you are looking for. The day I bought mine there was a guy cussing and pushing one back into the lot that he had just bought and rode off on, I have often wondered if his was the same problem. Ultimatly i think my little check valve thingy could have been installed upside down but I removed it before I learned how it worked. good luck and look at the path of the fuel. If it has the tank above there needs to be flow of fuel to the carb but there is also a vacuum operated petcock that stops the gravity flow unless the engine is cranking or running, it is easy to see a pic. of this small device on ebay as there is always several for sale under gy6 parts. You can pull the line off of this vac. petcock on the side leading to the carb. and see if fuel flows when you suck a slight vacuum on the port on the side. Just a good verification of supply side. The make sure that air is able to get into the fuel tank to replace the gas coming out to make it all work as needed. if it seemed to run a few miles and then die I bet it is what I am guessing above and the carb is not the ultimate culprit.
Post by ratrod on Apr 2, 2012 19:27:04 GMT -6
Post by ratrod on Apr 2, 2012 18:13:44 GMT -6
My 08 has a ballast resister but it looks to be in line with the ground side of the enrisher and reduces the voltage to 6.5 when I checked it with the fluke meter. Is this normal as I do not see the same device on a friends 08 Both of our voltages seem proper and stable. Could this be of any help.
