Post by gy6atv on Dec 1, 2012 16:27:17 GMT -6
Okay sweet as
Post by gy6atv on Dec 1, 2012 15:00:40 GMT -6
I just started the engine and ran it for the first time yesterday and noticed that the valve cover was getting really hot after about 5mins of idle, It didnt get any hotter after that time but when i did give it a little throttle it backfired or poped alot when i let off. Lean right? so i went into the top of the carb to move the clip down one but there isnt a clip in there just a needle and there is no markings on the needle suggesting there was ever a clip there, so how do i make the carb run rich other than a new jet? ??
Post by gy6atv on Dec 1, 2012 0:18:20 GMT -6
Another update Its running now just got it fired up today and ran it for 10 mins and am going to change the oil once it is fully cooled down then the run in begins. While it was running the valve cover got really hot like touch it for 5 seconds and you will be burnt hot, i dont know if thats normal? The carb settings are the same as stock so no new jets or anything havent changed anything. Do i need to adjust the richness or what help :/
Post by gy6atv on Oct 25, 2012 1:12:41 GMT -6
Bit of an update Im still getting an ignition coil and starter solenoid as i found out mine are both stuffed so i will be up and running as soon as i get them. cant wait
Post by gy6atv on Oct 4, 2012 0:35:43 GMT -6
Hey there everyone I'm from down under i have an ATV with a 150cc gy6 engine that i have rebuilt with a 61mm big bore kit just yesterday i finished rebuilding it and have to re wire it and then i will post a photo of the finished product. Good stuff on here love it Cheers
