Post by pepe0001 on Jul 29, 2013 10:57:40 GMT -6
I replaced the steering stem, but the gimbal (piece with u joints) doesn't fully attach at both the top & bottom making the handlebars jiggle. It appears to be too short by about a 1/4".
The bolts I removed to fix it got damaged (made of a soft metal) so I replaced them with hex bolts from the local home improvement store.
The design of the steering is flawed. I have a 2011 model. I don't recommend the independent suspension design. Bumpy roads cause both wheels to bounce separately in different directions forcing me to slow down. I saw someone riding a reverse trike with front wheels close together. it was more stable & could handle higher speeds with no trouble. Too bad I couldn't catch up to ask about it.
Post by pepe0001 on Jul 10, 2013 6:44:35 GMT -6
In California the only place I can find parts for this is at the dealership.
I have an alignment issue and now my steering stem broke. Neither one looks too difficult to fix.
MC_D50TKA
by: pepe0001 - Jul 9, 2013 13:53:12 GMT -6
Post by pepe0001 on Jul 9, 2013 13:53:12 GMT -6
I purchased a used MC_D50TKA that had about 600 miles on it and it worked great for a while. It just isn't built with quality in mind, but low cost. This trike isn't any easier to ride than a two wheeled scooter, and in fact, can at times be more dangerous because of the independent suspension. When hitting bumps or potholes the front wheels bounce separate from each other making it difficult to control.
My trike lasted about 1000 miles before the odometer, speedometer, and battery died. I just bought a new battery and used it as is until the steering/direction column broke after another 1500-2000 miles. I'm planning to buy the $70 part, repair it myself since the local dealership charges $70/hr for service, then sell it before something else breaks.
Oh, I think the front wheel alignment might be off so the tires are wearing out faster than normal and unevenly.
If you can get a bigger trike without the independent suspension you'll have a smoother ride and be able to keep up with traffic. The bigger ones just aren't legal in California so I didn't get much of a choice.
