Post by smiffy on Oct 6, 2013 11:08:00 GMT -6
If the stator was the problem why would it light up when the brake is applied that's the bit I can't work out.... My mates put a multimeter on it and it shows roughly 2 volts without brake applied then 12v with brake on he's leaning towards the control switch what do you think don't really want to order the parts till I'm sure what's causing it??
Post by smiffy on Oct 6, 2013 5:26:56 GMT -6
Hi guys I've got a baotian 50cc scoot I've got an issue with the front headlight it's really dim until I apply either brake then it lights up how it should.... Tried running separate earths to both tail unit and headlight with no change any idea what could cause this??
Post by smiffy on Oct 6, 2013 5:03:22 GMT -6
Spoke to soon!! Running fine but got an issue with front headlight it's really dim until you apply the brake then lights up as it should?? Tried running a separate earth wire from both the tail unit and front headlight but not making any difference.... Any other ideas I can try lads??
Post by smiffy on Oct 5, 2013 10:35:23 GMT -6
Yep it was a carb issue runs sweet as a nut now.... Just done a full service so hopefully no more problems for a while!! 😄
Post by smiffy on Oct 1, 2013 6:18:11 GMT -6
Cheers I'm doing a compression test tomorrow if that's fine then it could well be carb issue will strip it down to see
Post by smiffy on Sept 30, 2013 1:43:54 GMT -6
Hi guys I posted last week regarding power problem on a baotian 50cc scooter I thought I had found the problem with a split o ring in the inlet manifold but still only getting 8mph, so just bought the Haynes manual and discovered that the battery I replaced that was on the scoot ytx4l-bs (50cca/3ah) should be a ytx5l-bs (80cca/4ah) would this cause the power problem??
Post by smiffy on Sept 28, 2013 9:13:25 GMT -6
O ring I meant haha
Post by smiffy on Sept 28, 2013 9:12:52 GMT -6
Think I've found the culprit in respect to the power a split I ring on the inlet manifold I think the lack of power is what's causing the lighting problem too as checked all the electrics and they seem fine apart from someone butchering them!! Little bit of work and she should be back on the road cheers for the help lads!!
Post by smiffy on Sept 25, 2013 22:46:57 GMT -6
It does seem as if it's a fueling problem that's why I asked if there is a vacuum pipe to the air box from the carb it's the same sort of bogging down when the pipe pops of a car or bigger bike, cheers will strip the carb off and check the inlet manifold hopefully it's something simple also I've noticed when the side lights are on front and back light up as they should but when dip beam is on the light is really dim but when you apply the brake the lights come on as they should I'm assuming its a bad earth?? Any suggestions??
Post by smiffy on Sept 25, 2013 15:10:53 GMT -6
thanks alleyoop will take pics and upload them, yes it is a 4 stroke 58 plate with 2800 miles guy i bought it from said he washed it and then it wouldnt start no spark im not sure if he was being honest or not as i would have assumed it would have run ok now the spark problem is sorted also not sure what hes messed around with as it was obvious he had tried to sort the problem himself judging by the loose bolts and missing airbox etc!!
Post by smiffy on Sept 25, 2013 12:46:14 GMT -6
hi all new to scooters and have just bought a baotian 50cc bt49qt-9d non runner with no spark, managed to sort spark problem but scoot doesnt seem to rev up properly and has a lack of power approx 10mph on flat 5mph uphill almost coming to a standstill, there was no airbox when i bought the scoot so replaced with a new one is there a vacuum pipe that goes from the carb to it? is there any other reasons to cause this issue? any help would be great cheers
