Post by seafish on Mar 23, 2014 6:37:48 GMT -6
my question is do you have to have the kickstarter gear on the scooter, because I was trying to take the clutch off and my C clamp came around and broke it off the case inside. No case oil leaking from engine case I just try to put it back into the cam opening and the case is crack so I can't put it back in . So can I just leave it out of the scooter ?
Also other question I change the coil on the scooter also because my battery wasn't staying charge . So I replace it and its still not keeping charge I drive it daily and I have to charge it by the end of the week because the battery go dead . Yes it is a brand new battery , I bought that to thinking the battery was no good, but its doing the same thing to the new battery. also I have to take my fuse out every time I turn the scooter off because my tail light and headlight , and gauge lights stay on, don't know why but its a pain in the butt. I have talk about it before in other forms but everything guys ask me to check its good. On this problem I have change the refg. and coil , cdi , check my grounds,the control for the on and off switch , and key switch. still don't know whats wrong. So if I pull the fuse every time I turn the scooter off that should not pull on the battery still right?
Post by seafish on Mar 9, 2014 6:31:35 GMT -6
check your throttle cable on handle , it maybe getting hung up. That is what my did a twice almost had accidents over it.
Post by seafish on Jan 30, 2014 19:23:32 GMT -6
no I press the horn button and it did not sound.
Post by seafish on Jan 20, 2014 19:01:03 GMT -6
alleyoop, here is my problem now after I got it running , now i cant leave the fuse in the scooter my headlight and brake lights stay on all the time. So if I go to start the scooter I have to put the fuse in the fuse holder to start the scooter, after I get it started with the fuse in I have to pull out the fuse or my lights stay on all the time. But when I am riding the scooter and have to put on the brakes my headlight and tail light go's dim. like theres a short some where but I dont know were to start looking. So Like I said if I turn the scooter off with the kill switch, the head and tail lights stay on even if I turn the key to the off postion.
Post by seafish on Jan 13, 2014 18:40:00 GMT -6
NEED HELP AGAIN ALLEYOOP Got it running last week took it to get gasup and came back to the house turn it off, and turn the key to the off position went in the house, and on the weekend I was so sick with the flu i could not even get up to go see why I kept smelling gas in the garage so found out a week later, now the battery is dead because I had a hot wire I guess that kept pulling on the engine and kill my battery. So recharge the battery and the scooter starts up ok but now the scooter does not turnoff at all turn my key to the off position the bike didn't turn off or the kill switch didn't kill the engine either. the only way I was able to turn off the bike was to pull one of the coil wires off of it to kill the engine. I pull the fuse it didn't do anything for the bike my headlight was on very high, and the brake light also. but once I took out the fuse the headlight and brake light went down to normal brightness . I don't know what the H I did but I am Not good with electric on anything. can anyone tell me what the H I did to the scooter now?
Post by seafish on Jan 4, 2014 20:16:30 GMT -6
Got it fixed it was the brake button, plus the coil was sparking but it was very weak so change out coil with new one and started right up, all lights are now working, and headlight is too. Thanks guys.
Post by seafish on Jan 2, 2014 19:31:46 GMT -6
found my problem in my brake buttons, found that prblem now it trys to start but no spark now pull plug and not getting spark could be the coil . how do check to see if the coil is bad?
Post by seafish on Jan 1, 2014 11:02:19 GMT -6
Yes I did tvnacman thanks anyway
Post by seafish on Dec 30, 2013 19:39:26 GMT -6
OK did what you ask about checking the yellow/green wire and the tester did not light up, and jump the solenoid with a screw driver and no spark . so I am just going to wait for the parts I order to see if its the kill switch or the brake buttons, what else can I check I turn the key in the on position and my gas gauge moves up and my blinkers and horn works but no lights or able to start. can it be my coil? or do you think I shorted out my REF. it was new but the two wires I had that were hot before I plug in the New REF. are not hot now.
Post by seafish on Dec 30, 2013 18:54:14 GMT -6
how do you add photos here ?
Post by seafish on Dec 30, 2013 18:52:36 GMT -6
the answer your question about the gauges , i turn the key and the gas gauge moves up but my gauges light up only when the bike is running , and no to your other question my brake lite does not come on with my key, I have to have the key on and bike running in order for the brake lite work. all I did when I put the bike back together was all the plastic pieces I didn't pears no wires it was the front cover of the bike and side molding going back to the side fender.
Post by seafish on Dec 30, 2013 18:40:00 GMT -6
just got back on the message board to read more message thanks for all your help , I am working on it little by little . I have ordered a right side on and off switch to see if thats it. and also order two new brake buttons. I try pulling one out to see how it gos in but now I am waiting for the parts.. you ask about the model 150cc retro bacco I will try to post some photos that you ask for. I will be trying the solenoid tomorrow
Post by seafish on Dec 28, 2013 20:05:57 GMT -6
my battery is very good cond. also. for what I can make out were my all my wires are in front of the scooter they are all hook up but two that were not thing on them in the first place , because I tape them off so I knew not thing was on those two wires.
Post by seafish on Dec 28, 2013 20:01:29 GMT -6
I did all of that also, and I took a screw driver and put it on the + and - and the starter turns but don't start check the switches on handle bar and the switch is in the on position also. I did have headlight and brake lights after I replace the ref. but first I did what you said and order the stator first and replace that and that was not the problem the bike still started but the headlights and brake lights did not come on until I just decide to just buy the Ref. and put that on and everything was working . Just shut it down to put it all back together and not thing.
Post by seafish on Dec 28, 2013 19:01:52 GMT -6
I am still having problems former (WSONY) 150cc headlight don't work, had to sign back up on forum with new user name. That was the title of my post before....... so I got the new stator and that didn't make my lights work so I order a new ref. put it on and started up the bike and my headlights are now working . Now I just shut down the bike to put it all back together and nothing not even power to crane the bike everything is dead . it was not even 1 hr. and took it out of the garage after putting it all back together , no power to crank but the gauges work . someone please help I am trying even thing. the four wires that go to the ref. that I was told to test yellow and red were hot before I put the new ref. on was now no power at all , tested the same two wires there not even hot no longer. what could have happen?
