Post by scooterguam on Mar 9, 2014 4:22:23 GMT -6
Hi Members Im new to this forum and looking for some help to try to trouble shoot my gy6 150cc motor being very unstable with the idle and surging thing I have done already checked all the vacuum lines blowing smoke and also carb cleaner to trace any leaks..none petcock working good intake manifiold no leaks I did the smoke leak test and carb cleaner none insulator no leaks manifold gaskets new cam timing good aligned on the cam with TDC valves adjusted 004 005 head and cyl new no leaks spark plug new coil good strong blue spark drain the fuel added new fuel still the same jetting and piolt stock #35 #105 I have a video ill try to post it
Post by seafish on Mar 9, 2014 6:31:35 GMT -6
check your throttle cable on handle , it maybe getting hung up. That is what my did a twice almost had accidents over it.
Post by rob63 on Mar 9, 2014 7:20:58 GMT -6
It could be running lean, have a look here on how to adjust your mixture link
