Post by solarshedparts on May 14, 2014 10:26:29 GMT -6
Post by solarshedparts on May 13, 2014 17:22:55 GMT -6
ok i got to run to town. made a video on the moped. it will be viewable in 30mins or so.
Post by solarshedparts on May 13, 2014 17:15:56 GMT -6
alot of good info i like this site
Post by solarshedparts on May 12, 2014 6:24:06 GMT -6
i can spray starter flued in side the carb and no fire still. i talked one of my firends he think the timeing or fly wheel is messed up. will open it up tonight.
Post by solarshedparts on May 11, 2014 16:05:33 GMT -6
nope no fire. will see if i can get a different crab. too. im not seeing any mist come out of it now. but ther is gas in the bottom. will let you know next week when i have some more money.
Post by solarshedparts on May 11, 2014 14:58:26 GMT -6
You posted that 2 minutes After I responded and you did that within 2 minutes I may have been born late but not yesterday Bro! Alleyoop oh yea sorry about that. im logged in the laptop out in the shed. and been having the page open. i did not refresh it before my last post. where i did not see your new thread. in the other hole i tried to blow in it and no air would move and looking in it. its sealed inside the tube. so the other one right next to it lets a little air move so i took it that's the vacuum line. i spent allot of money and was all the wrong parts. spent 3 days trying to fix it. and back worst than i started. i just miss riding it. :/
Post by solarshedparts on May 11, 2014 14:20:03 GMT -6
well i put a regale cut off val. blocked off the vacuum. and had the carb lifted off and it still don't make a mist like it did before i cleaned it. my firend has a 110cc small 4 wheler moter and stuff hes trying to sale me. i might buy it off him for the pekcock and might see if i can use that carb. well i will make a new thread after i get more parts in and need help thanks for all the help and info. i might see if that dave dude has 80cc big bore kit that will work on this..
Post by solarshedparts on May 11, 2014 11:54:45 GMT -6
yea i think i messed up my petcock. now no gas come out of it.
Post by solarshedparts on May 11, 2014 10:28:37 GMT -6
i just retook it all apart again to check make sure nothing was clogged on the inside and to check the floot bowl is lvl. do you think i should take the gas value than that the vacuum goes to for the gas to flow and clean it up too?
Post by solarshedparts on May 11, 2014 8:35:19 GMT -6
i turned the idel one right some. and played with the lean mix it sounded like it fired once for a split sec. can you see if i have the hose on right place. my firend help me take it off i did not see where they was to start with. also when i put the jets back in i put them back in snug by hand screwdriver is that too tight?
Post by solarshedparts on May 11, 2014 8:22:07 GMT -6
Post by solarshedparts on May 11, 2014 8:20:07 GMT -6
Post by solarshedparts on May 11, 2014 6:41:09 GMT -6
just got up will get some coffee going and keep you posted on it soon.
Post by solarshedparts on May 10, 2014 22:14:43 GMT -6
Post by solarshedparts on May 10, 2014 22:07:26 GMT -6
i can add more tommrow
