Post by gmon on Jun 11, 2014 19:04:40 GMT -6
I actually thought of that might be a problem. I installed the hose all the way to the left and I have 2 inches clearance away from the tire. I shouldn't squirt since it goes first to the oil catch container, gets depressurized and cooled and then just drips down hopefully. I will still keep an eye on to see where will be dripping ![](http://i57.tinypic.com/33kgljq.jpg)
Post by gmon on Jun 11, 2014 18:38:08 GMT -6
Now, instead of plugging the hole on the air-box hose, I used a pcv valve. The valve only lets air in and not out. Since my engine is running rich at idling (because of the long intake pipe and the up-jetting)) this might help to breath a little better. The valve will also help to keep the pressure when scooping air with the intake, since is not letting air out ![](http://i59.tinypic.com/2a65r4h.jpg)
Post by gmon on Jun 11, 2014 18:22:55 GMT -6
Oil Catch and Release I had the oil catch kit for a while, so finally I got some time to install it. I read that the oil may foam up, so I decided not to install the part with the fitting in place of the oil cap, instead I just ran the hose to the back mudguard, so it can drip there. The reason I bought it was because I was getting oil inside the air box and my filter was wet at the bottom right corner - soaked with oil. Pics: ![](http://i62.tinypic.com/2q1ti0y.jpg) I also installed a computer fan to help cool down the vapors faster(I hope) Fan Front: ![](http://i57.tinypic.com/sbmxyw.jpg) Top View - I put an old fuel filter ...to the rear mud guard ![](http://i60.tinypic.com/alth93.jpg) ![](http://i59.tinypic.com/ll6b9.jpg)
Post by gmon on Jun 7, 2014 15:32:02 GMT -6
jct842 Why wrong? I said "My air is colder then a uni filter setup above the engine". Even if you are moving, the ambient temperature is higher there than the front for sure. And when you are not moving, your filter gets heated up and the stuff around your filter also absorbs heat and then radiates it. I only ride my scooter in the city, so its stop and go with few straits. I know "It would take some real engineering to design a ram that has the proper air/fuel mix", but that was not my goal to make it proper. I'm not an engineer, I read few thing about ram and my understanding is that Ram usually is most effective after 50 mph, the length of the pipe relates to what rmp's you will get the most gain (shorter pipe means max gain at higher rpm, longer at lower rpm). The opening of the ram air - the faster you go, the smaller the opening should be for maximum efficiency, going slower -bigger opening... So I wanted to experiment and I did get better results +3 miles top speed and faster acceleration to top speed. What is your gain from the uni filter?
Post by gmon on Jun 6, 2014 17:48:17 GMT -6
I was wondering what would be the maximum width tire for my stock 10 inch rims. My scooter is 50cc Chinese like tao tao and it has lots of clearance. My current tire sizes are 80x100-10 Thank You ![](http://i62.tinypic.com/16kb3a8.jpg) ![](http://i62.tinypic.com/2s8fg5u.jpg)
Post by gmon on Jun 6, 2014 16:48:17 GMT -6
Yeah man, the plastic white piece goes on top of the needle the way you have it on pic 2, but it needs to go further down. Check your needle if its positioned right. Then you put the spring on top of the white piece and close it
Post by gmon on Jun 6, 2014 16:36:29 GMT -6
jct842 that's right, but I wanted to do Ram air and create pressure at hi speed to force feed the air in the carburetor. My air is colder then a uni filter setup above the engine - the heat rises up. I don't know why my setup didn't work, but my guess is: 1) The 3 air filters I put prevented the air flow to go smoothly into the carb at idling and low speed, I should have tried with only one filter? or 2)for ram air to work you need a sealed container with volume (air box) to feed the air into. So the next thing I am going to do is seal the air-box completely with silicon, because right now I am sure that air escapes from it. They are not made air tide
Post by gmon on Jun 5, 2014 21:03:02 GMT -6
I would probably need fuel injection to work. I think the scooter when is idling is not getting to much air, because of the long intake pipe. But it runs good when I run it through the air box, so I don't know. I ended up with this setup: [img src=" i62.tinypic.com/20h9imf.jpg" src="http://i62.tinypic.com/20h9imf.jpg" style="max-width:100%;"] Now at top speed and down heal is running lean (have #85 and #38 jets), you can hear the air getting forced and sucked up
Post by gmon on Jun 5, 2014 20:50:53 GMT -6
Post by gmon on Jun 5, 2014 19:36:51 GMT -6
jvino I only have one scooter. jct842 I was thinking the same thing and I wanted to compensate with the larger carb jets, but it didn't work. The scooter lost power and speed but sounded nice. I used 3 filters between 3 of the joints. After 5 min of testing and failing, my spark plug went bad and got totally dark. I went back to the original design through the air box and the scooter runs good now. The fail video:
Post by gmon on May 28, 2014 19:47:23 GMT -6
Thanks jvino. Right now I don't have installed any of the vent filters because I still run through the air box(foam filter). When I go directly to the carburetor, I will install the filters between the two white plastic joints(last photo from the 3rd post), because is almost vertical there and hopefully will prevent clogging. There will be no other filters except the mesh. I am almost ready to go. This afternoon I cleaned my carb for first time and i fitted larger jets - #85 and #38. I watched a video on youtube on how to do it. I also replaced the cdi and coil cable with "racing". Anyone knows what are those two hoses for? They are hanging from the carburetor and are not connected to anything. The short one is making my carb dirty on the outside
Post by gmon on May 27, 2014 18:25:37 GMT -6
Thank You Rich, good to know
Post by gmon on May 27, 2014 18:23:43 GMT -6
The package of the filters I'm going to use. I think with 2 of this on 2 of the upper joints and I will be golden. The stock foam filter is not better filter in my opinion. I don't want to over do it with filters on more than 2 joints, because it may reduce air flow and that is the reason I am doing it. I am hopping for ram air effect at top speed and maybe create a 1 psi pressure? Currently according to my speedometer down hill I go with 53 mph. Before intake max was 50 mph. ![](http://i59.tinypic.com/2d27qm1.jpg)
Post by gmon on May 27, 2014 17:59:03 GMT -6
Thank you guys! So the crankcase breather hose I can just leave it hanging without plugging it when I get rid of the air box? jct842 I am not worried of debris going up my intake. I put a fine metal window screen at the tip. When I get rid of my air box, I will also put a cut out of vent filters on at least few of the joints. My first set up of the intake was with two vent filters on two of the joints, but I took them out since I am still running it through the air box. The hole for the intake is not directly behind the tire, but more to the left. I have been riding my scooter for almost a week since this mode and so far no debris in the intake pipe or the air box filter. I get 3 mph more top speed and now down hill accelerates a lot faster into red line. Yesterday I did 9800 rpm couple of times for several seconds with no problem(down hill). I have stock cdi and everything else is stock, except iridium spark plug. I ordered performance cdi and ignition cable and larger jets. Will see then... Intake opening behind to the right: ![](http://i57.tinypic.com/16atu8h.jpg) The filter I will be using between the joints: ![](http://i60.tinypic.com/2ilg9pw.jpg)
Post by gmon on May 23, 2014 13:32:19 GMT -6
But for the 150cc you will need to register and insure it. As far as I know the name brand of my scooter is Chuanl ![](http://i58.tinypic.com/f1kv83.jpg)
