Post by dwint on Mar 16, 2015 9:51:24 GMT -6
I fixed it by accident.i figured I get a new solenoid and when I went to plug it in I noticed they were melted all the way to the clip.it starts and operates normal.thanks for the help people
Post by dwint on Mar 15, 2015 5:06:01 GMT -6
im not sure.i wish I remember because that would be the obvious
Post by dwint on Mar 14, 2015 20:37:34 GMT -6
can some one tell me what size to upload my picture?this is my first picture posting and its so blurry.i cut off the plastic to the solenoid and wired the green to the post and the other to the other to the bottom of the solenoid and I think this is shorting out
Post by dwint on Mar 14, 2015 20:33:16 GMT -6
Post by dwint on Mar 14, 2015 20:26:38 GMT -6
I had some wires melt on me and fried the brake switch because I didn't have a fuse.i wired it so it would start without the brake switch.the brake light was always on.i rewired it and got a new switch.i put this lawn mower solenoid in and wonder if this is my problem.hope this pic gets posted and someone can tell me is there constant power or whats going on
Post by dwint on Mar 14, 2015 20:21:38 GMT -6
Post by dwint on Mar 4, 2015 10:22:02 GMT -6
you wouldn't believe what I did.last week I bought a new plastic piece for the front.well I had them wired right I just put the directional on the wrong side.i hardly use my blinkers so I never noticed it.thats another one fixed.it was a easy one but I was over looking the obvious
Post by dwint on Mar 4, 2015 6:21:44 GMT -6
cut each wire and replaced and soldered the ignition.bought a new brake switch but still waiting for it in the mail
Post by dwint on Mar 3, 2015 19:26:19 GMT -6
when I put my left or right blinker on its fine in the rear butwhen I do my left blinker in the front the right comes on and no blinker on the right.i changed the bulbs around and same thing.i recently had a short in the ignition and front brake switch was fried but the blinker looks fine.what could this be?i hope its not a short
Post by dwint on Mar 2, 2015 17:58:12 GMT -6
well I just put all the greens together (with yellow stripe)and all blacks together and its the same thing.also my blinkers are fine in the back but are opposite in the front.would a bad switch cause this or flasher
Post by dwint on Mar 2, 2015 17:16:46 GMT -6
I just changed out solenoid with original that wasn't it.i have the black wire tied to the green with yellow stripe that's how im getting it to start.im assuming when I put the green with yellow stripe from both brakes and connect it with the one green and yellow stripe.then take both black from the brakes and connect it with the black im good.then I just need to disconnect the black and green with yellow stripe.im understanding it now
Post by dwint on Mar 2, 2015 16:14:24 GMT -6
the wires from the switch aren't even in the switch ,neither is the left side.heres a thought since you mentioned solenoid.i installed one a few days ago made for a lawn mower and that might be why I was blowing fuses.i ran out of fuses and bypassed it that's how my wires melted.and yes my brake light is always on
Post by dwint on Mar 1, 2015 14:51:37 GMT -6
I would like to know if the two wires coming from the front brake switch are for the brake light or for starting when pulling in the lever.i took them off and now it starts without pulling in the lever.i like it like this but my brake light is always on.i know you asked for pictures,im working on it
Post by dwint on Mar 1, 2015 6:16:02 GMT -6
no I didn't know there was one
Post by dwint on Feb 28, 2015 20:11:02 GMT -6
I must of had a bare wire or more behind my plastic cover in front.the ignition wires all melted together and I fixed that.the wires that go to the front brake switch melted so I threw them away.it starts now without pulling in the lever witch I don't mind.what does bother me is when I put my left blinker on the right comes on and when I put the right on nothing happens.i can hear the flasher but no blinker.switched the bulbs and no different.also my brake light is always on.obviously something is wrong.i don't have the wires connected to the front right or the rear .I know im asking a lot of questions.its a 2011 jonway and cant find any diagrams on line
