Post by cfreeland on Sept 11, 2014 17:40:24 GMT -6
Do I have my lines wrong?. Is the vacuum line to my peacock supposed to go into the manifold?
Post by cfreeland on Sept 10, 2014 14:35:05 GMT -6
I tried the other carb but it looked like the electric lines were fried a little so I tried switching the pieces big mistake I stripped the small screws on the second one but got the ones from the first carb off
Post by cfreeland on Sept 10, 2014 13:18:10 GMT -6
yeah my other one has a screw
Post by cfreeland on Sept 10, 2014 13:13:21 GMT -6
its plugged like the picture
Post by cfreeland on Sept 10, 2014 13:05:17 GMT -6
Oh ok good thing I have a extra carb lying around not sure if it works or not
Post by cfreeland on Sept 10, 2014 12:43:51 GMT -6
I notice when I was turning it over now that I have corrected the fuel filter it's not filling up with gas I checked the petcock and its shooting gas just fine
Post by cfreeland on Sept 10, 2014 12:37:58 GMT -6
s26.postimg.org/am5z5h515/20140910_143000.jpgThe boot cap does look that way but its on there as far as I can get it on with out "manhandling it" I moved over about 2 to 3 chain links give or take And I don't see any other screw on the carb other than the throttle screw if thats what you mean
Post by cfreeland on Sept 10, 2014 10:00:03 GMT -6
I thought I would post a pic of my engine just to see if it is anything small that im missing
Post by cfreeland on Sept 10, 2014 9:25:57 GMT -6
This is where I have the timing now. Its sounding like it wants to catch and run but it still isn't drained my battery again so waiting for charge
Post by cfreeland on Sept 10, 2014 5:23:06 GMT -6
Ok thanks for that info I adjusting the timing again now. Will let you know how it goes but it has been sounding promising
Post by cfreeland on Sept 9, 2014 23:51:13 GMT -6
I just noticed something does the letters on the rocker arms have to be upright
Post by cfreeland on Sept 9, 2014 23:03:10 GMT -6
Ok I had it close but it was between the t and f mark. So I need to adjust it so its not between them.
Post by cfreeland on Sept 9, 2014 22:28:59 GMT -6
Does it have to be right on the T mark. I got it pretty close within cm's. Have to charge my battery for now oh and this is the pieces that I was showing you in the other images this is not mine I just found it on the internet
Post by cfreeland on Sept 9, 2014 21:21:54 GMT -6
I dont know if I should mention this but my variator fan moves both ways if I try to turn it
Post by cfreeland on Sept 9, 2014 21:08:34 GMT -6
Ok thank you
