Post by falstaff on Apr 2, 2015 14:44:11 GMT -6
Thank you. Anything I need to be aware of vis a vis alignment when I put the cover back on?
Post by falstaff on Apr 2, 2015 14:12:11 GMT -6
So, yeah I know. When I remove the cover to replace the belt, do I need to remove the kick starter lever?
Post by falstaff on Dec 8, 2014 12:30:52 GMT -6
All it does is switch between hi and/or lo beams. The lights are on all the time anyway.
Post by falstaff on Dec 3, 2014 16:15:12 GMT -6
Yeah, I am thinking I need to make my own as has been suggested. Thank you for all the awesome replies. You guys are tops.
Post by falstaff on Dec 1, 2014 16:22:53 GMT -6
Post by falstaff on Nov 21, 2014 10:30:59 GMT -6
Looked through both of the above mentioned sites and did not see the connector I am looking for. I may need to just go to rat shack and see what they have.
Post by falstaff on Nov 19, 2014 13:44:21 GMT -6
Does anyone have a source for the 4 pin headlight wiring connector that plugs into the switch, on the handle bars, on a 2008 Roketa Bali Mc-13-150? Can these be sourced locally? Don't want to have to buy a whole new harness. Thank you.
Post by falstaff on Nov 18, 2014 16:56:27 GMT -6
Was thinking about the possibility of going on a small tour of back roads here in Arizona on my Roketa Bali 150cc. An idea occurred to me, probably not original.
Is it possible to install an auxiliary fuel cell, possibly under the seat, something that could be removed and install as needed, with a switch to move from the main fuel tank to the aux fuel cell? Might make long stretches a little easier. Any input?
