Post by spiderjames on Jan 4, 2016 19:15:16 GMT -6
I have the opportunity to purchase a 2014 ruckus clone with 2600miles for under $400. It is a tow yard impound. Runs and drives straight with some damage to the rear fender and the rear brake lever. Some surface rust on the chrome. I think it might be a good buy. I am not afraid to wrench on it to get it road worthy. Later if I like it I can do the stretch lower thing and still be way cheap. Opinions?
Post by rapidjim on Jan 5, 2016 8:18:33 GMT -6
I will put it this way, if a customer came into my shop and offered me that scooter for that price, I would snap it up. I could part it out for more than that.
Post by cyborg on Jan 5, 2016 19:07:43 GMT -6
A massive score!!!! I'd grab it
Post by Alleyoop on Jan 5, 2016 20:02:48 GMT -6
BUT BUT, how come the handlebars and wheel are pointing to the left and the two headlights are pointing straight ahead HUMMMMMMMMMMMMMMMMMM
Post by spiderjames on Jan 5, 2016 20:21:28 GMT -6
I think maybe the ruckuses are like that. the lights are attached to the box on the front.
Post by rapidjim on Jan 6, 2016 8:05:42 GMT -6
BUT BUT, how come the handlebars and wheel are pointing to the left and the two headlights are pointing straight ahead HUMMMMMMMMMMMMMMMMMM The Headlights are attached to the battery box and always point forward, independent from the steering stem. Just like a hard mounted fairing on a motorcycle.
Post by spiderjames on Jan 11, 2016 16:17:37 GMT -6
OK. Picked up the Ice Bear today. Not 100% sure if I did good or not. I had trouble getting down to see it and didn't want to miss out(fear of loss ). I committed to the guy to buy it over the phone. Total cost: $413.23. It runs but it looks like it has been dumped on its side. Upon a visual inspection the frame looks straight but the front fork/triple tree is definitely bent and the rear brake lever is broken (knew that going in). I have no issue with doing the repairs. They are straight forward enough but are parts readily available? I see the levers on EBay but what about the triple tree?
Post by cyborg on Jan 11, 2016 19:44:23 GMT -6
Rapid Jim is the resident ice bear guru and dealer,,,I'm sure he can supply all of your needed parts
Post by spiderjames on Jan 18, 2016 15:03:44 GMT -6
Should I attempt to straighten it or just replace it? Generally I don't attempt to straighten suspension parts on my VWs when they are bent. I just replace. Opinions?
Post by jct842 on Jan 18, 2016 16:35:14 GMT -6
I would just get a replacement along with the bearings. Doesn't take a lot to mess the bearings up on one of them.
Post by jaxrhapsody on Feb 4, 2016 13:41:05 GMT -6
OK. Picked up the Ice Bear today. Not 100% sure if I did good or not. I had trouble getting down to see it and didn't want to miss out(fear of loss ). I committed to the guy to buy it over the phone. Total cost: $413.23. It runs but it looks like it has been dumped on its side. Upon a visual inspection the frame looks straight but the front fork/triple tree is definitely bent and the rear brake lever is broken (knew that going in). I have no issue with doing the repairs. They are straight forward enough but are parts readily available? I see the levers on EBay but what about the triple tree? Quite a few places to get parts from- even the Ruckshop. That's the firsr "stock Ruck" looking one, I've ever saw, I've always seen the "modded from factory" versions; already stretched, "performance" 2stroke looking exhaust, gokart looking read tire, blah. I wonder how well a Big Ruk clone would sell, since Honda only made them for 2years, some people still want them.
Post by spiderjames on Jul 8, 2016 19:42:38 GMT -6
Haven't been on here for a bit but thought I might post a pic of the scooter after I got her on the road. Didn't have to do too much. Fixed the bent steering stem. Replaced the rear brake levers, mirrors and the turn signal lenses. That put her on the road. Changed out the handlebars and grips just for looks.
Post by cyborg on Jul 9, 2016 8:10:00 GMT -6
Looking good ,,,very nice,,,should give you tons of miles if you take care of her
