Post by Alleyoop on Feb 1, 2016 20:39:01 GMT -6
Sure here is a Video on how to test a 3 phase stator: Alleyoop
Post by mickyb01 on Feb 7, 2016 10:14:15 GMT -6
Good morning, I watched the video and tested the stator as the video shows. All 3 checks failed, one was -(negative) 8, one was negative.06 and the last one was negative 10. What's the next course of action?
Post by Alleyoop on Feb 7, 2016 14:43:47 GMT -6
Your stator is shot you need a new stator. Alleyoop
Post by mickyb01 on Feb 7, 2016 17:00:31 GMT -6
Thank you
Post by mickyb01 on Feb 14, 2016 13:19:57 GMT -6
I removed the stator, but I got a lot of oil out from behind the cover. I want to send you a picture but I don't know how to upload it.
Post by Alleyoop on Feb 14, 2016 13:24:29 GMT -6
On the post section where you type look below and you will SEE
POST QUICK REPLY SPELL CHECK INSERT IMAGE and POST MOODS click on INSERT IMAGE and it will show your computer you then find you picture and load it up to your post.
Post by mickyb01 on Feb 14, 2016 18:30:50 GMT -6
Post by mickyb01 on Feb 14, 2016 18:37:04 GMT -6
I hope the picture helps, I can't locate a stator like mine (with the 4 yellow wires coming out of it. I'm talking about the odd one coming out of the side mickyb01 Alleyoop
Post by Alleyoop on Feb 14, 2016 19:14:45 GMT -6
Post by Alleyoop on Feb 14, 2016 19:21:24 GMT -6
Post by mickyb01 on Feb 15, 2016 14:36:09 GMT -6
It looks similar but it doesn't have the black box with 2 wires attached to it. Also is the stator supposed to be in oil?
Post by Alleyoop on Feb 15, 2016 15:01:11 GMT -6
That black thing is you PICKUP COIL and they sell those as well Some stators they add a new pickup coil with them some don't. And yes the stator is in oil so always drain the oil before taking the cover off. Alleyoop
Post by mickyb01 on Feb 15, 2016 17:39:57 GMT -6
What is your opinion, should I replace the pickup coil? If not how do I remove the wires from the gromet and insert the new wires in it?
Post by Alleyoop on Feb 15, 2016 17:58:45 GMT -6
I would see if you can find a stator and the pick up coil first. But if not just get a razor and make a slit in the gromet so you can slip the old wires out and the new stator wires in.
Post by mickyb01 on Feb 16, 2016 12:53:57 GMT -6
Ok, I ordered everything I will need, but I can't find the chrome high pressure fuel tube.
