Post by genest11 on May 4, 2011 11:20:18 GMT -6
I have searched several parts sites and I cannot find a turn signal switch or a replacement flasher (two connection) that works with leds. I have 2008 205b with the linhai engine. Can anyone point me to a site that carries these parts? Thanks all!
Post by runningslow on May 4, 2011 11:29:22 GMT -6
Vstar 650 Classic
Post by damin69 on May 4, 2011 11:42:56 GMT -6
Post by genest11 on May 6, 2011 6:28:49 GMT -6
Thanks for the info on the flasher! I needed a new flasher as I switched over to leds and the flash rate is almost at twice the rate it was with the bulbs.
Late last season the turn signal switch started acting up, it was difficult to turn on and almost impossible to shut off. I disassembled the switch and adjusted the small screw on the switch lever. Tighten the screw to much and it will not operate, I set the screw so it works properly but it loosens up and I am back where I started. I tried tightening the screw several times but it still loosens up and of course this always happens at the most inopertune time. Any suggestions are appreciated, I would rather repair than replace.
