Post by ccoon888 on May 17, 2012 15:48:09 GMT -6
Bought it in jan 12' Have had nothing but problems. Now my problem is it takes for ever to start then when it does finally start it pours white smoke. I thought i put too much seafoam in it and i drained the gas tank, now its running but now it wont go up to but 8000 when before it went to 10 11 easy and it pours white smoke anone have any suggestions for this Chinese POS!! Thanks, Chris
Post by rob63 on May 18, 2012 9:34:06 GMT -6
For starters try a new spark plug to see if that makes any difference. If not, pop the spark plug out and do a compression test, to check if the bore and rings are in an acceptable condition.
Post by sprocket on May 18, 2012 11:20:47 GMT -6
Are you mixing the gas to oil correctly? Using 2 stroke oil and not engine oil?
Live To Ride / Ride To Live
Post by richardthescooter2 on May 21, 2012 12:41:21 GMT -6
Maybe your running too lean, adjust your a/f mix screw, turn all the way in (count the turns) turn out 2 1/2 turns, see if that helps.
