Post by fido64 on Jul 6, 2012 14:19:13 GMT -6
what is the trick to repaint some body panels I keep getting some thing that looks like fish eye give me a hint please thank you FIDO64
Post by tvnacman on Jul 6, 2012 14:29:40 GMT -6
Fusion, read and follow the directions on the can.
Post by fido64 on Jul 6, 2012 14:43:12 GMT -6
what is fusion a brand of paint?
Post by tvnacman on Jul 6, 2012 15:41:13 GMT -6
Krylon or crylon
Post by fido64 on Jul 6, 2012 17:29:11 GMT -6
Thank you I will give it a try Fido64
Post by justbuggin on Jul 7, 2012 21:09:22 GMT -6
proper prep work is the key fish eye is caused by wax or grease etc. you need to clean the parts good with a paint prep that removes all the contaminates
Post by tvnacman on Jul 8, 2012 15:11:20 GMT -6
just , post a link .
Post by ibtrikin on Jul 28, 2012 11:32:33 GMT -6
Did you sand the old paint at all? 600 grit is good for that. Just sand until it's not shiny. Then clean everything real good. Fusion is a good choice for painting plastic.
Post by Deleted on Jul 28, 2012 13:25:39 GMT -6
yea sand it. My friend painted his scooter and sanded it down not sure what grit but did it with water and sandpaper. took him a while to do it but after everything he used primer from walmart and then painted. looked great
Post by rapidjim on Jul 29, 2012 9:06:00 GMT -6
Another thing that works well for prep work is yellow scotch pads, then wet sand with 600 to 800 grit, primer then paint with Fusion or a good paint that is made for plastics. Fish eyes happen when the surface is not prepped good or clean.
Another thing that helps over spray or paint in the air is to wet the floor before you paint and paint using saw horses. The air dried paint hits the water and stays there. Works really well if you are using a paint gun instead of "rattle" can paint.
Jim
Post by rgmarsing on Aug 29, 2012 16:41:14 GMT -6
Great tip on the wet floor Jim.
