Post by scootvirginia on Jul 15, 2012 12:59:29 GMT -6
Ok so My scoot has 1423 miles and I had some knocking, pinging and loss of power going up small hills. Never did this before so something is amiss. Adjusted the valves to .004 on both of them in the cold state. The exhaust was already good but the intake was tight .002 at cold state. Cleaned and gapped plug as well. After test run still the same. It seems going uphill is when it occurs. Starting out is fine, flat runs it is good and even down hill is good. Not sure what this is, so any advice is welcome.
Post by Alleyoop on Jul 15, 2012 13:22:53 GMT -6
What grade of gas are you putting in. Try a higher OCTANE and from a GOOD BRAND. You may have gotten some bad gas. Alleyoop
Post by sprocket on Jul 15, 2012 14:21:13 GMT -6
Might be running lean..? check your air/ fuel mixture...
But trying going up in octane first and if you can ....avoid ethanol blends...
Post by scootvirginia on Jul 15, 2012 14:25:58 GMT -6
Ok thanks; mid grade gas is from the usual place but will change anyway. Will inspect and check the air/fuel mixture settings. Will report back later today.
Post by Alleyoop on Jul 15, 2012 14:40:08 GMT -6
Just noticed what he has on the scoot, crap he has #85 main jet on a 18mm carb with stock Air Box and stock muffler. If anything he is running rich and is probably looseing some power. Also with this heat wave the carbs need to be leaned out. Alleyoop
Post by scootvirginia on Jul 15, 2012 15:30:57 GMT -6
Well it was the air/fuel adjustment 3.5 turns out; (not sure if that indicates anything or not) did not change the gas, as one adjustment at one is the rule. That took the problem away and pulls up the hill like it was before. The plug was tan so I did not think it was running lean.
I have three of these scooters and the list in the sig is not the problem one. The one you guys just fixed is bone stock. Actually now that you pointed that out I need to adjust that list as I am pretty sure I am back to the stock main and pilot jet due the richness it was giving me.
On another note, if I changed the CDI and the Coil to the orange high output and the blue CDI on scrappy dog does anything else require adjustment due to this change or do you see any ill effects forthcoming?
By the way thanks for quick and accurate advice. You have saved the day.
Post by sprocket on Jul 16, 2012 16:28:22 GMT -6
Snitt..Alley good call on the jetting... ;D
Save your money on the orange crap...same as stock, but it costs more...no advantage... get NCY if you want expensive quality parts...still no power advantage, except reliability.
Post by scootvirginia on Jul 16, 2012 20:52:25 GMT -6
Ok great thanks for the help and saving me money.
Post by petrol42 on Jul 18, 2012 13:48:44 GMT -6
Well it was the air/fuel adjustment 3.5 turns out; (not sure if that indicates anything or not) did not change the gas, as one adjustment at one is the rule. That took the problem away and pulls up the hill like it was before. The plug was tan so I did not think it was running lean. I have three of these scooters and the list in the sig is not the problem one. The one you guys just fixed is bone stock. Actually now that you pointed that out I need to adjust that list as I am pretty sure I am back to the stock main and pilot jet due the richness it was giving me. On another note, if I changed the CDI and the Coil to the orange high output and the blue CDI on scrappy dog does anything else require adjustment due to this change or do you see any ill effects forthcoming? By the way thanks for quick and accurate advice. You have saved the day. I have the same problem so I was wondering if you turned your air/fuel screw in or out?
Post by scootvirginia on Jul 18, 2012 18:05:49 GMT -6
I turned it out so it is richer. Made a world of difference
Post by petrol42 on Jul 18, 2012 21:16:45 GMT -6
Nice, thanks for the reply!
I hope this works for me.
Post by scootvirginia on Jul 19, 2012 14:53:18 GMT -6
No problem, hope it does too.
Post by parkrider on Jul 19, 2012 16:22:19 GMT -6
yes the spark retardant in 89 made my bike run much better, a better you could hear.
experiment with Seafoam too
