Post by gy6ownsall on Aug 15, 2013 14:51:44 GMT -6
I was wondering if any autparts stores or mower/tractor stores that sell/stock a compatible belt for the long case gy6 835-20-30 belt. My scooter is my only transportation so i am not able to pull mine off and try to go match it with the looks of another. Thanks
Post by Alleyoop on Aug 15, 2013 14:53:53 GMT -6
Try Napa they probably will not have it in stock but they can order one for you. Alleyoop
Post by tvnacman on Aug 15, 2013 15:05:53 GMT -6
I was wondering if any autparts stores or mower/tractor stores that sell/stock a compatible belt for the long case gy6 835-20-30 belt. My scooter is my only transportation so i am not able to pull mine off and try to go match it with the looks of another. Thanks Are you sure that is a long case engine ? What size wheels ? How many bolts hold the cvt cover on ? I have both size belts for the 150cc's here in NY if your on the east coast You would get it Monday . I doubt an auto parts store will get it any sooner . John
Post by gy6ownsall on Aug 15, 2013 15:51:43 GMT -6
Try Napa they probably will not have it in stock but they can order one for you. Alleyoop Is there any other way i can tell the people at napa what size belt i need? i tell them 835-20-30 and theyre having trouble understand what number means what (length,width etc)
Post by Alleyoop on Aug 15, 2013 16:52:46 GMT -6
The LENGTH=835mm, the WIDTH=20mm, the Angle=30 degrees. If not why not just order from one of the scooter dealers TVNACMAN has them as well as many others. Alleyoop
Post by tvnacman on Aug 15, 2013 17:23:22 GMT -6
The LENGTH=835mm, the WIDTH=20mm, the Angle=30 degrees. If not why not just order from one of the scooter dealers TVNACMAN has them as well as many others. Alleyoop Alley he has stated he has an 835 and a long case engine that does not jive . John
Post by gy6ownsall on Aug 15, 2013 19:39:38 GMT -6
I just didnt want to order if it was possible to find 1 in town. Ordered both 842 and 835
Post by Alleyoop on Aug 15, 2013 19:58:16 GMT -6
The LENGTH=835mm, the WIDTH=20mm, the Angle=30 degrees. If not why not just order from one of the scooter dealers TVNACMAN has them as well as many others. Alleyoop Alley he has stated he has an 835 and a long case engine that does not jive . John What does not JIVE JOHN, most of the long case motors come with a 835-20-30, you have two types of LONG CASE motors one motor is a little longer due to the scoot having 16" wheels. But all the others have 12-13 inch wheels which take the long case motor. The 842 belt will also work, but like I said most 12-13 inch wheeled scoots they put on a 835 belt. Alleyoop
Post by kz1000st on Aug 27, 2013 18:49:03 GMT -6
What you have to do is find the Gates part number. The 743-20-30 for instance is PL30707. If you can find a picture on some online seller it may have the Gates number on it. If you have to order from NAPA you'll find Scooterbelts.com is actually cheaper even with shipping. Been there. Although partsforscooters.com is high on my list.
Post by LUKE on Aug 27, 2013 21:06:18 GMT -6
o lord, these belts from napa,autozone,o'reilly, lowes ,home depot etc are NOT design to withstand high RPM...jizz! get the number on the side of the old belt and you can buy these belts online...brand new!
Post by rapidjim on Aug 28, 2013 7:32:00 GMT -6
o lord, these belts from napa,autozone,o'reilly, lowes ,home depot etc are NOT design to withstand high RPM...jizz! get the number on the side of the old belt and you can buy these belts online...brand new! Once again you don't know what you are talking about. I have gotten Gates Powerlink Belts for scooters and ATVs from both NAPA and O'Reillys in the past when I have run out and needed by the next day. A Gates Powerlink belt is the same belt no matter who you buy it from. Jim
Post by bo on Aug 28, 2013 7:46:37 GMT -6
scooterbelt.com has them for 15 bucks. order today be there friday
Post by jct842 on Aug 28, 2013 12:46:00 GMT -6
Oh by the way LUKE........just how long does it take to get a belt for the sausage? Last belt I ordered for that majesty took over 2 weeks from a yamaha dealer too, don't ya just luv yamaha's quick parts delivery? I see why you like the trailer.
Post by gy6ownsall on Aug 29, 2013 7:49:07 GMT -6
Alley he has stated he has an 835 and a long case engine that does not jive . John What does not JIVE JOHN, most of the long case motors come with a 835-20-30, you have two types of LONG CASE motors one motor is a little longer due to the scoot having 16" wheels. But all the others have 12-13 inch wheels which take the long case motor. The 842 belt will also work, but like I said most 12-13 inch wheeled scoots they put on a 835 belt. Alleyoop Got both belts in awhile ago, just went to put them on to see the differences, glad i bought both sonce it was actually an 842, not an 835. I put the 835 on, but it was pretty hard to get on. Since its alot tighter, would i have better low end? Will the belt not climb the drive pulley all the way?
Post by kz1000st on Aug 29, 2013 20:00:42 GMT -6
Back when PhilR had his Carino he talked to John at GS Motorworks. John told him the best tuning trick for the long case GY6 Carino was installing an 842 instead of an 835. The 842 gave more top end. The 835 was installed on the Carinos to keep the top end down for safety since it did not reach the highest part of the variator. Phil put the 842 on and noticed a few mph more in his top speed.
