Triangular Shaped Head!!
Post by FACE PLANT FOR LIFE on Oct 7, 2013 18:41:14 GMT -6
So I've been noticing that mid-riding, my gas gauge will just..turn off. Stop showing anything. Just show zero. And then sometimes (not likely) it will come back up to displaying a proper amount if I hit a bump or something (maybe it's related.). But most of the time the ignition needs to be turned off and then back on again for it to start working. Until today. Today it just stopped working mid-ride and won't work at all now. What should I check to make it work again?
Post by Alleyoop on Oct 7, 2013 19:06:28 GMT -6
Post by sumdawgtwigg on Oct 7, 2013 19:13:38 GMT -6
Mine does the same, i need to check it out as well.
Post by shop242 on Oct 8, 2013 5:06:12 GMT -6
Fuel Sending Unit ??
Post by jct842 on Oct 8, 2013 12:38:48 GMT -6
I gave a friend a used 50 that has a bad connection under the speedometer housing....one of the plugs....fuel sending unit is not high on list of suspects but those connectors and plugs are.
