Post by Alleyoop on May 10, 2014 20:53:54 GMT -6
IF it is a DC CDI the power wire going into the CDI will have 12volts with the KEY on that is how you will know if the BLACK CDI is a DC CDI. If the power wire going into the CDI has no power with the KEY ON then it is an AC CDI.
I have to ask if your BLACK CDI is working why are you changing it?? Alleyoop
Post by solarshedparts on May 10, 2014 21:01:06 GMT -6
IF it is a DC CDI the power wire going into the CDI will have 12volts with the KEY on that is how you will know if the BLACK CDI is a DC CDI. If the power wire going into the CDI has no power with the KEY ON then it is an AC CDI. I have to ask if your BLACK CDI is working why are you changing it?? Alleyoop it wont start. my first post on this thread go in d tale what happen. the new video you can hear it trying but not checking.
Post by Alleyoop on May 10, 2014 21:18:16 GMT -6
Yes but that is not DUE to the BLACK CDI it is firing the plug so that is not your NO START PROBLEM BRO. It is either no compression or a fuel problem plain and simple Or no GROUND FROM THE MOTOR TO THE FRAME.
I noticed you are checking for spark on the FRAME NOT GOOD. you have to check for spark ON THE MOTOR. If the MOTOR IS NOT GROUNDED good the spark plug will not fire while in the motor. So do that TEST AGAIN BUT HOLDING THE SPARK PLUG ON THE MOTOR ITSELF. IF IT SPARKS ON the motor Then do the following:
So leave your BLACK CDI on and put the plug in the motor and crank it. Now after the no start pull the plug out and see if it is WET or DRY. Test that and get back with results Alleyoop
Post by Bashan on May 10, 2014 21:22:31 GMT -6
Call John aka TvnACman who runs NYC Tested Parts and he has a tile at the top of the site. He's a good dude and will help you out. He's also an electrician for the City of NY but don't hold that against him. I think he has to get another CDI Alley...JMO. Rich
Post by Alleyoop on May 10, 2014 21:28:49 GMT -6
EXPLAIN to this dummy WHY HE HAS TO GET ANOTHER CDI when the BLACK ONE HE HAS FIRES THE PLUG. Which means his CDI is good his coil is good his pick up is good his stator is putting out. Alleyoop
Post by solarshedparts on May 10, 2014 21:31:52 GMT -6
Yes but that is not DUE to the BLACK CDI it is firing the plug so that is not your NO START PROBLEM BRO. It is either no compression or a fuel problem plain and simple Or no GROUND FROM THE MOTOR TO THE FRAME. I noticed you are checking for spark on the FRAME NOT GOOD. you have to check for spark ON THE MOTOR. If the MOTOR IS NOT GROUNDED good the spark plug will not fire while in the motor. So do that TEST AGAIN BUT HOLDING THE SPARK PLUG ON THE MOTOR ITSELF. IF IT SPARKS ON the motor Then do the following: So leave your BLACK CDI on and put the plug in the motor and crank it. Now after the no start pull the plug out and see if it is WET or DRY. Test that and get back with results Alleyoop i got spark with it on motor, and far as the wet or dry it dose feel dry. i cleaned out the card the other day but i might have not ajusted some thing right. frist post why i cleaned the carb iwas costing down a hill and herd some odd noise and i dropped down from 35mph to about 20 it was bogging out. i let off the gas and then re-gave it gas and it picked back up then it got back up to about 35mph and bogging out again. then i costed to a stop light and it died and would not start again. i cleaned the carb. and then checked the spark. i got a new spark plug. Read more: scooterdoc.proboards.com/thread/9989/yamaha-2002-vino-help-time#ixzz31NHWvoAv
Post by Alleyoop on May 10, 2014 21:36:40 GMT -6
There you go the motor is not getting fuel. Now what type of carb do you have put a picture of it of the LEFT SIDE of the carb so i can tell you what to try. Alleyoop
Post by solarshedparts on May 10, 2014 22:07:26 GMT -6
i can add more tommrow
Post by solarshedparts on May 10, 2014 22:14:43 GMT -6
Post by Alleyoop on May 10, 2014 22:36:43 GMT -6
I want to see it on the bike all sealed up with the air filter on it and ready to rock and roll. The LEFT side and the RIGHT side and the hoses going to it and from it. There should be some adjustment screws on the left side of that carb need to see those or if you can tell me. ONE SCREW should be right in the center of the carb usually with a spring behind it some without a spring that would be your IDLE SPEED SCREW(turning that Clockwise raises the IDLE and Counter Clockwise lowers the IDLE).
Another Screw will be either by the AIR FILTER side or the INTAKE SIDE. IF the screw is on the AIR FILTER SIDE that is a AIR RATIO MIXTURE Screw( turning that Clockwise feeds it more fuel Counter Clockwise LEANs the mixture out). IF the screw is on the INTAKE SIDE that is a FUEL RATIO MIXTURE Screw( turning that Clockwise LEANS it out Counter Clockwise feeds it more fuel). Alleyoop
Post by tvnacman on May 11, 2014 5:44:02 GMT -6
if your hell bent on making another cdi work I can help you with that . You will need to check for 12vdc on one of the wires at that cdi harness . I have the harness plugs for the cdi you were trying to connect with tails and both ac and dc cdi .
I agree with Alley it is a fuel problem not a spark problem .
Post by solarshedparts on May 11, 2014 6:41:09 GMT -6
just got up will get some coffee going and keep you posted on it soon.
Post by solarshedparts on May 11, 2014 8:20:07 GMT -6
Post by solarshedparts on May 11, 2014 8:22:07 GMT -6
Post by solarshedparts on May 11, 2014 8:35:19 GMT -6
i turned the idel one right some. and played with the lean mix it sounded like it fired once for a split sec. can you see if i have the hose on right place. my firend help me take it off i did not see where they was to start with. also when i put the jets back in i put them back in snug by hand screwdriver is that too tight?
