Post by Bashan on May 11, 2014 10:06:43 GMT -6
My premise was that he was trying to adapt an arcane wiring configuration into the run of the mill CDIs that we deal with here on the forum. I guess I wasn't into problem solving as much as I made it a theoretical enigma. I didn't even notice the other CDI was working.....my bad. Rich
Post by Deleted on May 11, 2014 10:24:11 GMT -6
i turned the idel one right some. and played with the lean mix it sounded like it fired once for a split sec. can you see if i have the hose on right place. my firend help me take it off i did not see where they was to start with. also when i put the jets back in i put them back in snug by hand screwdriver is that too tight? the jets in the carb bowl? yes just tight and snug with a screwdriver. -Edit- looks like you got it together right as in the hoses and stuff as well.
Post by solarshedparts on May 11, 2014 10:28:37 GMT -6
i just retook it all apart again to check make sure nothing was clogged on the inside and to check the floot bowl is lvl. do you think i should take the gas value than that the vacuum goes to for the gas to flow and clean it up too?
Post by Deleted on May 11, 2014 11:40:50 GMT -6
no dont clean the petcock. theyre easily damaged. just suck on the vaccuum line and see if gas comes out the outlet
Post by solarshedparts on May 11, 2014 11:54:45 GMT -6
yea i think i messed up my petcock. now no gas come out of it.
Post by Deleted on May 11, 2014 13:46:26 GMT -6
theres your problem. gonna have to order a new one
Post by Alleyoop on May 11, 2014 14:18:00 GMT -6
WAIT JUST A COTTON PICKEN MINUTE. Your Petcock does it have a VACUUM connter or is it a OFF/ON valve type Petcock. Because if it is a VACUUM line operated PETCOCK it needs VACUUM and you do not have the VACUUM HOSE connected to the CARB going to the PETCOCK. Here is your VACUUM port on the CARB you need a VACUUM hose on there and connected to the PETCOCKS Vacuum connector OTHERWISE no gas will come out to the carb. IF you have a OFF/ON fuel valve that you manuall have to turn on and off then you need to plug that VACUUM CONNECTOR UP on the carb. Alleyoop
Post by solarshedparts on May 11, 2014 14:20:03 GMT -6
well i put a regale cut off val. blocked off the vacuum. and had the carb lifted off and it still don't make a mist like it did before i cleaned it. my firend has a 110cc small 4 wheler moter and stuff hes trying to sale me. i might buy it off him for the pekcock and might see if i can use that carb. well i will make a new thread after i get more parts in and need help thanks for all the help and info. i might see if that dave dude has 80cc big bore kit that will work on this..
Post by Alleyoop on May 11, 2014 14:22:51 GMT -6
You posted that 2 minutes After I responded and you did that within 2 minutes I may have been born late but not yesterday Bro! Alleyoop
Post by solarshedparts on May 11, 2014 14:58:26 GMT -6
You posted that 2 minutes After I responded and you did that within 2 minutes I may have been born late but not yesterday Bro! Alleyoop oh yea sorry about that. im logged in the laptop out in the shed. and been having the page open. i did not refresh it before my last post. where i did not see your new thread. in the other hole i tried to blow in it and no air would move and looking in it. its sealed inside the tube. so the other one right next to it lets a little air move so i took it that's the vacuum line. i spent allot of money and was all the wrong parts. spent 3 days trying to fix it. and back worst than i started. i just miss riding it. :/
Post by Alleyoop on May 11, 2014 15:12:20 GMT -6
That other open port on the carb is there a screw in there? Or is it just blocked up? Alleyoop
Post by Alleyoop on May 11, 2014 15:54:25 GMT -6
Take that Vacuum line off and squirt some gas down it not to much put the vacuum line back on and see if it FIRES. Alleyoop
Post by solarshedparts on May 11, 2014 16:05:33 GMT -6
nope no fire. will see if i can get a different crab. too. im not seeing any mist come out of it now. but ther is gas in the bottom. will let you know next week when i have some more money.
Post by Deleted on May 11, 2014 17:36:44 GMT -6
sorry alley, i didnt see that nipple unhooked there. on my phone and pics are small.
Post by solarshedparts on May 12, 2014 6:24:06 GMT -6
i can spray starter flued in side the carb and no fire still. i talked one of my firends he think the timeing or fly wheel is messed up. will open it up tonight.
