Post by jojo on May 15, 2015 8:32:33 GMT -6
Thats your emissions or PAIR i believe its called I dont know for sure so I wont give you any answers but if you search the forum for PAIR removal there are many writeups with the information youre looking for
Post by jojo on May 15, 2015 8:10:32 GMT -6
cyborg I havent been on this forum long now,as I only recently obtained a dismantled disaster scooter for free from a friend and Im starting to think Alley may not like me he hasnt chimed in on any of my posts yet
Post by jojo on May 15, 2015 7:49:06 GMT -6
Just a quick and to some stupid question the wiring harnesses for these scooters is typically a 16 gauge??? And the battery terminals Im guessing 10 gauge? Thanks for the help
Post by jojo on May 13, 2015 13:46:51 GMT -6
Well I don't want to thread jack you here. But I'm working out some little links here and there. If you don't mind I'm going to PM you.
Post by jojo on May 13, 2015 11:17:52 GMT -6
The scooter was given to me in pieces from a friend. The motor is the scrappy dog gy6 200 B.
Post by jojo on May 13, 2015 11:07:25 GMT -6
Oh no doubt for sure. I'm still pecking away at my gy6 200 it sucks when you are getting progress and then hit a stopping point bc of misc parts needed here and there.
Post by jojo on May 13, 2015 10:47:30 GMT -6
Im still patiently waiting to see you bust out that gy6 200 B case and see what you do with it. dmartin95
Post by jojo on May 13, 2015 10:30:18 GMT -6
Awesome man.
Post by jojo on May 12, 2015 10:42:01 GMT -6
Also wondering about the fuel tank nipples. Thanks
Post by jojo on May 12, 2015 9:59:23 GMT -6
1. From valve cover I think is a vent so leave it open somewhere??? 2.Vac line to "T" into 3. and go to fuel petcock 4.Fuel in coming from petcock 5. I have no clue.
Thanks in advance
Post by jojo on May 12, 2015 9:57:19 GMT -6
Post by jojo on May 12, 2015 9:56:04 GMT -6
I think I have this figured out but want to double check with you guys first.
Post by jojo on May 8, 2015 19:06:38 GMT -6
So you want to do a stretch type scooter like a mad dog I take it,,,you will need to move all the existing mounting points back the same amount for all equally ,,,if you don't cut the existing mounts and use them you need to fabricate new ,,,,as far as shock length if you are using the original upper mounts that will be determined when you get the front of the engine hanging on the new mount then the desired ride height can be determined,,,,unless you have a long case it's a no go on the 16",,,the oil lines can be trimmed ,,,if the existing lines are crimped ,,cut in the middle and use double ended barbed hose couplings with new clamps,,,this should not be an issue with pressure cause it is very low Thanks man.
Post by jojo on May 8, 2015 12:18:12 GMT -6
Any and all advice or reccomendations welcome
Post by jojo on May 8, 2015 12:17:20 GMT -6
