Post by ghcoe on Aug 16, 2015 11:31:24 GMT -6
Doing a update here. I just installed my speedometer this last weekend and thought I would do a translation from Engrish to English.....
Red: Connect to constant 12V (direct battery voltage)
Brown: Connect to switched 12V (switched voltage from the keyed switch in the "on" position)
Green: Connect to negative/ground
Yellow/White: Connect to fuel float if 3 wire signal 500 ohm fuel sender
Yellow/Green: Connect to fuel float if 2 wire signal 100 ohm fuel sender
Light Blue: Right turn signal
Orange: Left turn signal
Blue: High beam indicator
Red/White: Connect inline with "trigger wire" to CDI. This wire can be Red/White, Blue/Yellow, or Blue/White.
Notes:
I found that I only needed to connect 1 wire to the fuel float in my application. I had a 3 wire float and in my case the Yellow/White wire was the same on the scooter. I just taped the unused wires up and connected the two Yellow/White wires together and gage worked fine. It was half full when I hooked up the gage and just to see if it was working right I started to add gas and watched the gage. As the tank filled gage went up and showed full once full.
In my case the Red/White wire for the "trigger wire" was the same color as my scooter had for that application.
Post by ghcoe on Jul 27, 2015 21:02:29 GMT -6
You got to love living in California.....
Post by ghcoe on Jul 23, 2015 21:18:19 GMT -6
Post by ghcoe on Jul 18, 2015 22:20:39 GMT -6
Old train depot is the next tag.
Post by ghcoe on Jul 18, 2015 8:46:46 GMT -6
Not sure why they would not show up. Pictures on another site would not show up ether. Hope they are working now. Now I show two pictures of each photo. Weird.
Post by ghcoe on Jul 17, 2015 22:38:40 GMT -6
Ok, here is the church.
Now lets find a old train depot.
Post by ghcoe on Jul 16, 2015 17:47:14 GMT -6
Built my confidence on the road. Well worth the coin to take.
Post by ghcoe on Jul 15, 2015 17:23:51 GMT -6
Found this on a site that sells that speedometer.
Red: battery positive terminal of the electric door locks come in here (keep always have electricity Flanagan) Brown / Black: electric door lock control closed positive (by the positive control switches) Green: Negative Yellow / White: 3-wire fuel oil floating signal line 500 Europe Yellow / green: 2-wire 100 ohm fuel oil floating signal line (2-of-2 oil floats a look at his car crossing a line connected to pick which one you can empty a) Light Blue: right turn instructions Orange: Left turn instructions Blue: Indicates beam Red / White: engine speed to engine trigger coil (also known as the pulse coil)
