Post by conora on May 16, 2016 14:33:35 GMT -6
I'm starting to think the rings could be the problem but would that cause it to blow white somke though the head?
Post by conora on May 16, 2016 10:32:49 GMT -6
I can feel air comeing out of the valve on the head I'll take it apart later and look into it. Any idea why I'm getting this extra pressure now?
Post by conora on May 15, 2016 22:55:31 GMT -6
At tops maybe 300 miles since I put the bbk in and it wasn't doing this before I replaced the oil pump.
Post by conora on May 15, 2016 21:25:13 GMT -6
Tank urban 50 I though the same thing so I drained about half of it and it still has the same problem.
Post by conora on May 15, 2016 17:30:39 GMT -6
Installed new oil pump and now I am burning oil and blowing white smoke out of the head. The vent hole on the head is working but apparently not well enough.I just put a dip stick oil decompresser with a catch can on but it didn't help much. BTW I have a 100cc bbk it was originally 50cc, straight pipe and many other performance upgrades.
Faster!
by: conora - Feb 24, 2016 21:15:34 GMT -6
Post by conora on Feb 24, 2016 21:15:34 GMT -6
No just weights, what variator would you recommend?
Faster!
by: conora - Feb 24, 2016 20:56:54 GMT -6
Post by conora on Feb 24, 2016 20:56:54 GMT -6
I have a 2007 tank urban 50 moped with a BBK, new ignition coil, new cdi, new air intake, straight pipe, 95 jet and 9g roller weights. Right now it tops out around 45. I was wondering what would be the next step to make it even faster? Thanks!
Post by conora on Dec 26, 2015 16:09:47 GMT -6
I can't start my moped with the electric start. It will turn it over but won't fire even when connected to a car battery. But if I give it a few kicks it starts right up. I just put a 100cc BBK in from a 50cc.I put a new starter motor in about 3 months ago. Is this the starter motor or could it still be the battery?
Post by conora on Dec 6, 2015 18:15:39 GMT -6
I set the rocker arms to.004 and I put a 95 jet from a 90
Post by conora on Dec 6, 2015 16:38:08 GMT -6
Just installed a 80cc BBK on my 50cc scooter it turns over good but will not start. I checked the spark and I can feel compression with my finger. I know gas is getting into the carb but not sure it's getting to the engine.
Post by conora on Nov 12, 2015 16:01:52 GMT -6
Just put in a 100cc bbk and a k&n style air intake what size main jet should I get for the carborator to get the right air fuel mixture?
Post by conora on Oct 27, 2015 15:51:17 GMT -6
I'm planning on buying a 100cc big bore kit for my 50cc tank moped what is a good kit and what kind of speed can I expect from it my moped goes 30mph now
Post by conora on Oct 23, 2015 15:59:30 GMT -6
Feel really dumb now that I realized this but the green wire is actually the ground for the bike. But I found the new solinoid is shot and once I replace that I think it will work.
Post by conora on Oct 23, 2015 15:05:33 GMT -6
Post by conora on Oct 23, 2015 12:00:38 GMT -6
I connected the jumper cables to the battery and bridged the terminals of the solinoid and it still just clicks. But when I connected the power cable to the starter and grounded it on the moter it did start up. There was a wire to the solinoid and a harness that hasn't been replaced with the solinoid or the starter so I brought the two in to a parts house and they are both still good. So I connected the jumper cables directly to the wires off the moped battery and the solinoid still clicks.
