Post by cptk on Jul 17, 2011 23:56:08 GMT -6
Hey Kiwiscoot, Definately Smile at your miles.. Iknow I am smiling at mine. It is good to know I have a common Link to some one out there...
Post by cptk on Jul 17, 2011 19:19:35 GMT -6
Way too expensive...But still an option
Post by cptk on Jul 17, 2011 19:10:03 GMT -6
Hey alley, Excellent info... but yea my head is a little spinnin.. So if I go up on the clutch teeth and down on the trani teeth I get higher top end? And where by chance do you get such a thing?
Post by cptk on Jul 17, 2011 18:18:07 GMT -6
Well there is a lot that has gone kaputi...I have replaced One stator, a regulator, two coils, a couple of plugs, a Battery, Three back tires, Three mufflers, Replaced all fuel lines and Vacume lines, fixed numerous Electrical connections ( mostly by soldering the wires and eleminating the plugs ), Added all LED's throughout the system, and also added a Led light bar across the trunk, I use 91 octane, and have replaced coolant twice, Replaced a mirror (dont ask why), Changed to 12gm Sliders, and several belts ( some just to try for fun ) and have replaced brake pads, as well as bled the brakes a time or two. All in all I think that is it and not too bad for 20K......Lookin to post the fifty/k in two years or so. So Scoot on peoples....
Post by cptk on Jul 16, 2011 21:16:19 GMT -6
Hey my wife says I have A bubble butt no where near iron...But the scooter Rocks . Old Blu has only let me down a couple of times. The linhai engine is a good one for sure.
Post by cptk on Jul 16, 2011 18:38:58 GMT -6
I was just wondering how many other people have made it this far? And what issues have you had? Attachments:
Post by cptk on Jun 4, 2011 16:13:48 GMT -6
There are only a couple of things that would make it stick...Does the temp gauge fluctuate after it comes on???
Post by cptk on May 30, 2011 20:55:42 GMT -6
Hey Bashan, I am up in th foothills of northern calif. I did have sucess today monday. After a good day Sun. was able to put some saelant on the trani side of the scoot and actually had to make my own gasket for the right side since I ordrered wrong gasket/ or did not check it when it came. L.E.D.'s did not come in yet so I will have to wait. But I do believe oil leak is gone. If I was a better with the tech side I would post pics. . Nice thing though was I broke my gas recirc. tip on air box and tried to J.B.Weld it Sun....Broke it Mon. putting it together, got into my bucket of nuts&bolts found a plumbing compression fitting same dimensions and screwed it into air box like it was meant to be...and low and behold it works like a charm..I so love those fixes. It is amazing what you can find in your bucket of miscellaneous.
Post by cptk on May 29, 2011 22:41:27 GMT -6
Hey Alleyoop, Thanx a bunch...I guess the two are not the same...That is what I get for thinking huh....Thank you again
Post by cptk on May 29, 2011 21:50:11 GMT -6
Hey Guys, I am looking for the fastening nuts for the clutch and or variator. Where can I order from. The local hardware store does not carry the correct pitch for the nut. they have 14mm nuts and bolts but it is like 100mm pitch. And with one revolution it stops. I have a linhai 257/ with a 16 spline off the gear box. The one's I have still work but am looking for replacements before it is too late. The socket size is your typicall 19mm. I know I saw them somewhere but OOPPPS I forgot. I know pay a little more attention when I am poking around. Help PLease Thanx
Post by cptk on May 29, 2011 21:10:36 GMT -6
Little update, After all of my whinning yesterday I got a nice day Sunday to get out and tear in to the scoot...Hopefully Monday proves to be just as nice. Even though it was ill weather Saturday I did have a great day with the family inside the house...Wathching movies,played some video games with the youngest one had lunch with the oldest .. all together not a bad day after all...just a whinny butt...
Post by cptk on May 28, 2011 18:25:43 GMT -6
The 3/4 will work for a 19mm but am not sure on the plug. My plug is an 18mm and I would definately find such a socket to remove. Maybe an 11/16 would work instead of 18mm but I am not for sure. But for sure if you remove the plug it will make it easier to turn over the motor.
Post by cptk on May 28, 2011 18:19:28 GMT -6
philosophydoc is soo right.. With the pipe thing. Some of us guys call it a breaker bar to sound more manly I guess. Anyway next time try his trick I can assure you it will work.
Post by cptk on May 28, 2011 17:56:33 GMT -6
Hey Todd, Right now I am running a 228x23 belt in my 250. Your 856 will work just fine. Like Jr. said it will improve your pick-up but lose a little on top. This little belt I am running now is incredible at stop, but when driving up hill on the highway it does suffer. bought 2 new 856's and am planning to replace if it stops raining long enough/ along with a few other things.
Post by cptk on May 28, 2011 17:45:39 GMT -6
I am sooo with you on this..I am ready for the rain to stop for a while. I will give it my best prayer for ya. I hope you have great ride. But no fair complaining how hot it is in two weeks from now.....
