Certified Clinician
Post by deanc on Aug 12, 2011 19:46:14 GMT -6
so re did it all. now everything good but got a squeak.
Certified Clinician
Post by deanc on Aug 11, 2011 18:42:39 GMT -6
ok seafoam and cleaned power back but hard vibration on take off. but has top end. hmm weight outta the track?
Certified Clinician
Post by deanc on Aug 11, 2011 6:01:41 GMT -6
just did the filter a week ago. is the carb why i have a lack of power now? could the idle be turned down too low?
Certified Clinician
Post by deanc on Aug 10, 2011 10:25:55 GMT -6
I expected it to run better, and am hoping its related to bad gas. do i just drain the bowl, or remove and disassemble?
Certified Clinician
Post by deanc on Aug 10, 2011 7:38:12 GMT -6
does the new clutch have a break in period?
Certified Clinician
Post by deanc on Aug 10, 2011 7:36:33 GMT -6
Also there is no water in the oil or viceversa, oil is very clean as is the new coolant. Is it possible that the plug got messed up through all the work and bad gas?
Certified Clinician
Post by deanc on Aug 10, 2011 7:34:58 GMT -6
with the help of everyone here I have managed to adjust the valves, change the fluids, the plug. Clean the air filter and the belt. I have just finished replacing the clutch, I ordered this one, this is for the mc 54-250b by the way. www.roketapartsonline.com/baja-atv-parts-clutch-assembly-11-16-splines-for-chinese-250cc-300cc-engines-p-9156.htmlI counted the plines and they match. I tried sliders but went back to the rollers. all clean and properly installed. I went back to the gates belt that was on it because the new belt was cheap and filled the cover with black crumbs/dust. The old belt was fine the squeaking was the clutch. so..... everything was fine till I got cheap crappy gas and changed these parts. I drained the gas from the tank and replaced it with no ethanol gas 93 oct. so now I wonder why the seeming lack of power? the belt size is 856, same as before when it did have more top end. I just did the valves last month, and the plug. the idle is at 1500, the timing is lined up. Could the new firmer clutch cause this? where the old worn out clutch allowed more top end with this belt. feels like it lacks take off and power at 50 mph doesnt want to really take off from there.
Certified Clinician
belt???
by: deanc - Aug 2, 2011 9:13:41 GMT -6
Post by deanc on Aug 2, 2011 9:13:41 GMT -6
THanks Alley, I'll leave it alone. It does 70 I dont feel safe going any faster than that anyway.
Certified Clinician
belt???
by: deanc - Aug 1, 2011 17:07:42 GMT -6
Post by deanc on Aug 1, 2011 17:07:42 GMT -6
so i should have went with the longer belt?
Certified Clinician
Post by deanc on Jul 29, 2011 20:52:40 GMT -6
anybody know of any rides in the nashville area?
Certified Clinician
lcd clock
by: deanc - Jul 28, 2011 17:21:56 GMT -6
Post by deanc on Jul 28, 2011 17:21:56 GMT -6
yeah i'll try again and let it go. radio, I found that i can use the fm on the mp3 player and run it through the scooter radio via the jack. works much better.
Certified Clinician
lcd clock
by: deanc - Jul 28, 2011 6:43:47 GMT -6
Post by deanc on Jul 28, 2011 6:43:47 GMT -6
yeah but I didnt unhook the battery it just loses time. i set it yesterday and a few hours later it was again right about where it started. I dont want to buy an instrument panel just to fix the clock. Maybe I'm setting it wrong, its seems pretty easy, but there might be a last step i'm missing.
Certified Clinician
lcd clock
by: deanc - Jul 27, 2011 20:11:09 GMT -6
Post by deanc on Jul 27, 2011 20:11:09 GMT -6
the little clock on the gauges loses time, does anybody know if it just uses a watch battery? guess I'll find out when I replace the speedo light.
Certified Clinician
safety tip
by: deanc - Jul 27, 2011 7:47:36 GMT -6
Post by deanc on Jul 27, 2011 7:47:36 GMT -6
i bought the scoot used and have done alot but not that, i'm taking the wheels today to have new stems and be balanced. my wife rides and I dont want that happening to her.
Certified Clinician
safety tip
by: deanc - Jul 26, 2011 21:16:13 GMT -6
Post by deanc on Jul 26, 2011 21:16:13 GMT -6
i was test driving my scoot after a belt replacement and all seemed well. It seems that the new rear tire I had mounted last week, the guy didnt change out the valve stem, and the old one decied that it wanted to blow out. so at 20 mph in a turn it got wobbley and I had to pull over to find that the rear tire had no valve stem and was flat. ****lesson learned when having new tires put on request new valve stems as well**** or you could be looking for a ride home too.
