Post by howfar on Nov 21, 2012 14:27:15 GMT -6
Is it only two places i need to check for bad fuses on this kind of scooter ( Roketa 250cc -MC-54-250B) 2008? that is next to the battery and the back right lower side.
Post by howfar on Aug 13, 2012 7:10:33 GMT -6
I changed all Fuses - the one by the battery (RED WIRE) and the one on the right lower side of the scooter. still no power.
Post by howfar on Aug 12, 2012 15:17:01 GMT -6
I have 250cc Roketa scooter battery cable got transposed now scooter won’t start (no power) changed all fuses still won't start. Will a bad CDI box cause the scooter not to have power (no electricity)?
Post by howfar on Jun 30, 2012 11:37:16 GMT -6
if i tried jumping across the terminals would this restore power to the scooter?
Post by howfar on Jun 29, 2012 17:44:25 GMT -6
I have a roketa 250cc scooter 2008 , The terminal battery cable got switch around now scooter won't start at all (no sound just dead) i know it need a electrical part but not sure what the name of the part is.
I replaced both fuses on bike and and had battery checked still no power. scooter was running good before cable got switch. Is there anything else i should check?
Post by howfar on Jun 24, 2012 12:27:05 GMT -6
If that fuse is bad would this stop the bike from starting(No power)?
Post by howfar on Jun 23, 2012 8:21:04 GMT -6
Can somebody please help me? I accidentally transposed my battery terminal. Scooter is dead, I changed the fuse next to the battery but scooter is a still dead. Are there more fuses on this bike ( Roketa 250cc -MC-54-250B) 2008 and if so can someone please tell me where i can find them?
If you changed the Fuse on the RED wire coming off the battery and when you turn the key on IF your instruments lights come on and the fuel gauge works etc. Then you have powr to the ignition switch. If still no lights and fuel gauge doesn't work then you must have a box with more fuses. Some fuse boxs they put under the seat near the battery with a cover on it. Some are in the glove box etc..
If you have power to the ignition switch but when you press the start button nothing happens. FIND the SOLENIOD some have a fuse on them that might be blown if it is NO JUICE will go to the starter. Alleyoop
Post by howfar on Mar 4, 2012 18:43:14 GMT -6
Post by howfar on Mar 4, 2012 16:27:05 GMT -6
I will try that thank you.
Post by howfar on Mar 4, 2012 16:08:39 GMT -6
