Post by aaronp1217 on Aug 19, 2013 7:44:49 GMT -6
Hi guys I'm back again after a very long time to come back and mess with this little evil demon of mine, I am seeming to have a problem getting the gas to pull throw the lines, I can't remember what I was showed last time to fix it as the person didn't talk just pointed n grunted any helps please and thanks
Post by aaronp1217 on May 8, 2013 19:53:41 GMT -6
Hi I posted on the forum a few weeks back about my scooter not starting I've done all of the same things I have poured gas directly in the the manifold and it still did not start. And my scooter makes the same exact sound as remi2k7 any help would be greatly appreciated I used to be able to get it to start after about fifteen mins of kick starting my scooter but now it will not do anything except for make the sounds remi's made in his video any help would be awesome thank you
Post by aaronp1217 on Apr 22, 2013 17:51:03 GMT -6
I have adjusted the valves it .003 charged battery so it's good cleaned the carb no start becacuasrbweak spark on spark plug new plug so it's just not getting the juice to fire was told it's either the coil or the exiter ihoe could I tell which one it is?
Post by aaronp1217 on Apr 19, 2013 0:18:38 GMT -6
Thanks for the tip my friend
Post by aaronp1217 on Apr 18, 2013 10:31:20 GMT -6
Okay quick steel, I was wondering about the kneels thought it might have to high of a chemical reaction and thought it might melt the plastic
Post by aaronp1217 on Apr 18, 2013 1:03:33 GMT -6
Spark plug* sorry iPhones autocorrect. And if any one has any more help with my problem would be much appreciated
Post by aaronp1217 on Apr 18, 2013 0:58:14 GMT -6
Hi i recently ran in to the screen door on my porch I was thinking once I get it proppey held in place to Scott's paint tape around the light then bondo and sand it down even then a black coat with and acrylic finish the. Light sand paper in an get and massage the acrylic down to an even finish does this sound good or is there a better way to do it with out replacing it.
Post by aaronp1217 on Apr 17, 2013 0:13:17 GMT -6
Ally would it matter if I told you I replaced the alarm plug not even ten miles ago and with the best autozone had and yes that is my scooter
Post by aaronp1217 on Apr 16, 2013 16:11:37 GMT -6
The throttle body is on the right side of the carb of standing behind the bike it's self and I did what you said and it built more compression but not even to start you could Acutally hear it turn over
Post by aaronp1217 on Apr 16, 2013 10:03:10 GMT -6
Sorry I never awnsered what type of hose it was it was the hose that connects to the manifold of the scooter
Post by aaronp1217 on Apr 16, 2013 9:13:32 GMT -6
Yes that was the term for the vacuum line, I wasn't to sure on some of the names for the hoses I did a little more research yesterday, I reset the fuel air mixture by turning it all the way clockwise then I backed it out two and a half turns, I could not even get the scooter to start after spraying carb cleaner inside the carb for a quick start would not even sputter it feels like it has compression. I am having a hard time figuring out the make and model of the scooter I have a parts catalog that came with the owners Manuel the only thing that gives the engine a small chance at identifying are the engel models inside the parts catalog one is. Two stroke and one is a four stroke the two strokes engine model is 1E41QMB and the four stroke is 139QMB. Any more help on identifying the scooter make and model would be awesome thank you in advance Sorry if it takes a while or I can't do stuff as I'm doing all of this from my iPhone no access to a computer or tools the only tools I have are what came with the bike and that's a double sided fourteen/ twelve. Wrench a double sides ten / eight wrench a small screw driver and and Allen key
Post by aaronp1217 on Apr 15, 2013 8:41:40 GMT -6
I have a 2009 Lottus 50 cc moped I'm having problems getting it started it takes a out ten to fifteen minutes to start no matter the weather and I have to charge the battery every single day I have cleaned the carburetor numerous times and when trying to create vacuum through the pump with the small black hose connect right in front of the throttle cable when watching the fuel pump you ca. See it makes a small movement but then it feels like it clogged up and can't get taste any gas that way any help please
Once I figure out how to put photos up I will show what my carb looks like
