Post by dklarz on Oct 4, 2015 17:05:06 GMT -6
2011 Jonway YY250T with a Helix 244cc. The bike will start and run in idle but die when I give it gas. Replaced the fuel filter and fuel pump - didn't help. Without buying a new carb in hopes that that'll fix it, what can I do to check the carb to see if that's the real problem? Thanks.
Post by dklarz on Jul 15, 2015 14:33:50 GMT -6
I have a Jonway YY250T with a battery/charging problem that I’m fighting to isolate. When I turn the key to start, I get nothing. Not even a solenoid buzz. I will get a flasher click on and off if I forget to turn the turn signal off but that’s it – no lights, horn or anything else. I carry a little booster battery with me and the bike will start very easily every time I use it. But I have to use it every time I start the bike. I replaced the battery last year and it worked for a while but got very tired at the end of the summer. I jumped an ammeter between the battery and the positive cable and didn’t see any obvious drain on the battery when the bike was not running. I removed the negative cable from the battery while it was running to check alternator output and it ran fine. I do have a problem with the clock running slow – loses about 5 minutes a day. And my fuel indicator quit working. I cut a hole in the plastic over the gas tank to get the float out but can’t because of the frame is in the way. I disconnect the radio mainly because it wouldn’t turn off on occasion when I turned the bike off. I can’t think of anything else to try. Any ideas?
Thanks - Dave
Post by dklarz on Jun 5, 2014 9:21:41 GMT -6
I've had a Jonway YY250T for a couple of years now. Generally it's been a good bike for me other than the normal Chinese issues (clock runs slow, radio sucks - I disconnected it, speedometer is off, fuel gauge doesn't work,...) When I started it this Spring, the starter "lagged" when I turned the key. Everytime I start the scoot, the started hesitates before turning over. I haven't had a problem getting it started but I'm afraid I could end up stranded. Any ideas what could be going on?
Thanks - Dave
Post by dklarz on Apr 20, 2014 7:55:35 GMT -6
How do I remove the gas tank from my 2011 YY250T? Need to fix the float but can't get to it because of where the tank is...
Thanks
Post by dklarz on Mar 30, 2014 12:35:45 GMT -6
How do I get to the gas tank on my 250 scoot? My gas gauge quit working and I suspect the float is malfunctioning. Had that happen on a 150 that I own. Thanks.
Post by dklarz on Mar 2, 2014 10:01:32 GMT -6
Where in the heck in the starter on my YY250T Scoot! My solenoid will run until I kill the battery but the starter won't kick in - I thought I'd try knocking the starter to see if it'll kick but either can't find it (I might have) or don't know what it looks like. Thanks - Dave
Post by dklarz on Jul 14, 2013 8:18:38 GMT -6
Thanks to all for the responses! As I'm new to this site, I'm pretty impressed with all the help...
bobf: The scoot has the 244 engine, supposedly a Helix clone. And, of course, the scooter is a Reflex clone. I have service manual for both the Helix and Reflex. No help with troubleshooting my problem.
That's exactly how I set the idle. Learned that from a motorcycle-owning brother.
kz1000st: I did check the fuel pump by disconnecting and cranking the engine. I'd get a intermittent spurt about 2 to 3 inches which is what I expected. Wouldn't that rule out the fuel pump? Is there a spec that I can measure with a vacuum gauge (like the old cars)?
I've also heard that it could be the carb - bad float or something. Don't know much about carbs - does that make sense?
I also found out after I bought the scoot that it isn't really new - it's a 2011 model - meaning that it probably sat in a warehouse for a couple of years. Could this cause problems that need attention?
Post by dklarz on Jul 13, 2013 14:19:32 GMT -6
I bought a new YY250T 3 month's ago. Last week it started acting up by stalling when I stopped. When I got it started, I had to "pump the throttle" to get enough revs to sputter the 6 blocks home. After a holiday weekend out of town, I couldn't get it to start. I checked fuses, spark at the plug, fuel filter and fuel pump. All seem to be working fine. I removed the gas (I use 92 octane) and replaced it with fresh. I sprayed carb cleaner and got it to run for about 5 minutes, had to "pump the throttle" to get it to rev higher than idle (about 1800 rpm's) then it stalled. Won't start again. Any ideas where I should go next?
