Post by xing150 on Jul 15, 2013 1:20:25 GMT -6
That thing is sweet! I may have to look into something like that
Post by xing150 on Jul 15, 2013 1:11:07 GMT -6
Awesome.....hope it fires for ya, I realllllllly don't see why it wouldn't after all this work!
Post by xing150 on Jul 15, 2013 1:07:36 GMT -6
I am picking up a couple filters first thing I can, have a pretty healthy dose of gumout carb and choke cleaner in the tank right now hoping to see if that will help out some. Will post back once I get some more info
Post by xing150 on Jul 14, 2013 21:22:51 GMT -6
After messing with the fuel needle...got about 40 almost out of it now but still bogging out....what else should I try?
It starts right up first try hot or cold....so pretty sure I got the carb set right. Thinking may just ride it and see if it'll work itself out...don't really need it to go over 30 for a lil while anyways.
Post by xing150 on Jul 14, 2013 21:20:06 GMT -6
According to your drawing, the petcock off your tank is what we'll call the fuel pump. The spaceship was part of the emissions system that can go bye bye. Starting fluid should really be sprayed straight in past the air filter for a straight shot into the carb.
Did you block off that vacuum line?
Post by xing150 on Jul 14, 2013 21:09:02 GMT -6
Welcome aboard!
I'm new too but lots of good info here as I've seen. See ya around!
omg..
by: xing150 - Jul 14, 2013 13:06:13 GMT -6
Post by xing150 on Jul 14, 2013 13:06:13 GMT -6
oh wow xing150 you explained it really good. It's a gift....what can I say? lol
Post by xing150 on Jul 14, 2013 13:01:53 GMT -6
Here.....I showed you on your diagram now.
Post by xing150 on Jul 14, 2013 12:56:34 GMT -6
Looking at it now....awesome drawing..You sir are an artist....seriously Anyways, bowl drain hose comes off the bottom. Your vaccum and fuel line are hooked up correctly. For right now, you can take that "T" fitting off the line going to the intake (orange) and plug it off. You don't need all the extra crap right now just to fire up. Realistically you should be set to go. Try it after plugging off that line.
Post by xing150 on Jul 14, 2013 12:43:31 GMT -6
Oh I didn't know that you didn't have that part on the carb.......Makes this semi easier possibly.
Plug off the 3rd vaccum line off the "T" fitting. Take a small screw and put it in the end or what not. Make sure your spaceship is letting fuel get into the carb. It should start from there.
Post by xing150 on Jul 14, 2013 12:08:40 GMT -6
Agreed.....check your variator weights, and belt condition, and go from there.
Chopped VW
by: xing150 - Jul 14, 2013 12:07:14 GMT -6
Post by xing150 on Jul 14, 2013 12:07:14 GMT -6
haha that thing is pretty sweet if you ask me....Reminds me of the Micro machine cars that you wound back, stick a penny in the back of it and would do lil tricks n stuff LOL
Post by xing150 on Jul 14, 2013 10:00:38 GMT -6
You just like to fart and then leave the room. That's the best part of farting if you ask me lol
Post by xing150 on Jul 14, 2013 9:57:07 GMT -6
Do a search here for the variator and should find some helpful procedures to diagnose.
Post by xing150 on Jul 14, 2013 9:53:17 GMT -6
Bumpity bump bump.......
Pulled the diaphram out and all is peachy in there....immaculate and no rips or tears.....only have three adjustments on the needle, was in the middle now I have the clip on the lowest setting to see if maybe can get something more from it.....but the bugs were eating me alive so I haven't tried retuning it yet. I at least got it to start right up and that was it.
But, what other suggestions would there be possibly?
