kymco Bikes
by: earthman - May 16, 2011 10:57:52 GMT -6
Post by earthman on May 16, 2011 10:57:52 GMT -6
89newbie
a dollar saved is a dollar earned.
I think we should put KZ in charge of finding the best deals on the net, with a finders fee.
bet he would get rich quick.
Post by earthman on May 16, 2011 10:52:37 GMT -6
how do you get it up on the back?
kymco Bikes
by: earthman - May 14, 2011 10:33:20 GMT -6
Post by earthman on May 14, 2011 10:33:20 GMT -6
yes kz and it appears folks are reporting parts jam ups from japan
kymco Bikes
by: earthman - May 12, 2011 22:15:42 GMT -6
Post by earthman on May 12, 2011 22:15:42 GMT -6
I have always looked at the pcx as nothing short of beautiful. and am sure it is dam bullet proof bike and better then sym or kym. but too little power, for me, i have to dodge red necks a lot. having got my first bike behind me, i think sym or kymco anything 200-250 up must be next. But Zingyue could not have treated me better. BELOW KYMCO 250 4200.00 REAL BUCKS Attachments:
MPG
by: earthman - May 11, 2011 10:28:12 GMT -6
Post by earthman on May 11, 2011 10:28:12 GMT -6
hI mike !
on first "feeling glance" it is a desire of many to open air intake and sometimes it works great because of leaks in the "passage" from filter to head, but many folks have just heated up their engine and only gained 3 miles worth of speed, at the cost of the bikes longevity.
But the fact is a oiled filter will never clean air like a high micron paper one.
Plus you are displacing oxygen with oil vapor on a uni, a be it little tho.
I have talked to some guys who went with a uni and spent weeks getting it (bike) back to the running normal they had before install, tho many pop on and work great.
That swerved path to carb is there to compensate the cyclone turbulence and drag normal to any air path, i wish you all the good i can muster on such a mod, but must tell you, taping the connection leaks with tape, a layer of high temp silicon at the intake connection like the factory used and vacuuming the paper filter most times will never let you down.
You really gotta think a minute about trying to hype up a little gy 6, if you get it to its greatest burn and power are we not just burning it out ?
I think the greatest mods are those that bring the bike into "STEADY STATE EFFICIENCY" which includes not just speed and power but longevity.
If you want to do a great mod, get the air box to stop sucking hot air from the engine area and re route the air intake to get cold air away from the bikes interior heated area.
I run wet to save the engine, with only 180 cc's and not being willing to mess with water cooling, the main thing on my mind is keeping the timing chain path cool and never going more then half throttle, which gets me 50 mph by the DOT radar sign on my street.
When i started my mods i was running about 20 degrees hotter then i do now, I see xingyues with 15 and 20,000 miles on them, that's my goal.
when i want a super ride i start rubbing my girlfriends back, who is another space in my life i have modified with poetry, flowers and good health.
All things in balance.
MPG
by: earthman - May 4, 2011 23:07:56 GMT -6
Post by earthman on May 4, 2011 23:07:56 GMT -6
I run my 180 cc a tad wet for longevity cooling issues and only get about 55 mpg about 90 octane and snyth oil, cold carb- no EPA heat returns hooked up.
Post by earthman on Apr 19, 2011 19:59:20 GMT -6
yep so fregging cool!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
carburator
by: earthman - Apr 18, 2011 23:27:15 GMT -6
Post by earthman on Apr 18, 2011 23:27:15 GMT -6
welcome ironworks, do you work rebar?
hold out till rapid jim chimes in here, he has made some very sincere efforts to know the ice bear in and out.
ERRATA?modify, wow as i wrote this, the thread above this appeared above when i posted.
Post by earthman on Mar 21, 2011 14:24:53 GMT -6
VERY COOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Post by earthman on Mar 4, 2011 12:21:53 GMT -6
mcalli
my girlfriend pointed out your post here , we could not be happier for you if we tried.
Post by earthman on Mar 3, 2011 0:53:24 GMT -6
eh bashan we love ya man, but ah, ---baby crib springs that do nothing? folks shaking heads, toilet tubing on carbs? is not that engine gonna get real hot with out a shroud? ?
Post by earthman on Feb 27, 2011 23:12:47 GMT -6
hi BASHAN
in last pisture-
I have never seen a vac line go into a dia head like that please explain.
1 how is filter held on?
2 why so many ground wires
3 does it help to have rectifier so close to spark.
4 what is a rectifier
5 what do all those springs do on fork.
6 is that some sort of CAL CARB system behind carb?
Post by earthman on Feb 5, 2011 2:59:14 GMT -6
thanks BASHAN,
this is good theater for learning and very generous pic's.
